DIR-835EOL EOS
Wireless N750 Dual Band Router
Tanımlama
Extreme Speed with Dual Band Wireless N and Gigabit Technology
The D-link DIR-835 Wireless N750 Dual Band router allows you to check e-mail and browse the Internet using the 2.4GHz band while streaming High-Definition (HD) movies and other media on the 5GHz band all at the same time for smooth playback with no interruptions. The Gigabit ports of the DIR-835 allow users to reach peak connectivity speeds, and dual band technology supports both 2.4GHz & 5GHz wireless signals, making all of your network connections fast and reliable.
Powered by HD Fuel with Intelligent QoS
Harness the power of HD Fuel to watch movies and play online games with superior router technology. HD Fuel combines the speed and clarity of the 5GHz wireless band with an advanced QoS engine to create a high quality HD media experience. The DIR-835 uses D-link intelligent QoS Prioritization Technology to analyze and separate your wired and wireless traffic into multiple data streams so applications like VoiP, video streaming, and online gaming can be given priority. HD Fuel combines raw speed with this smart prioritization to give you an uninterupted multimedia experience.
Share a Multifunction Printer or a USB Storage drive
By using the SharePort Plus Network USB utility, users can share printing, scanning, and faxing functions across an entire office or home by simply connecting a multifunction USB printer. In addition, users can also connect a USB hard drive to create a shared storage space for computers and devices on the network, making it easy to share photos, documents, and media files with a home or office.
IPv6 Ready
The DIR-835 supports the IPv6 standard and is compatible with IPv6 equipment from other manufacturers. Users are able to upgrade to a 128-bit addressing system to directly connect to anyone around the world using a unique IP address. This router is capable of handling routing for both IPv4 and IPv6 networks simultaneously, providing forward and backward compatibility for a flexible router that meets your needs both today and tomorrow.
Genel Özellikler
Standards
• IEEE 802.11n
• IEEE 802.11g
• IEEE 802.11a
• IEEE 802.11b
• IEEE 802.3
• IEEE 802.3u
• IEEE 802.3ab
WAN Connection Type
• Static IP
• Dynamic IP
• PPPoE
• PPTP
• L2TP
Device Interfaces
• Four 10/100/1000Base-T LAN ports
• 10/100/1000Base-T WAN port
• USB 2.0 port
Antenna Type
• Three external reverse SMA dual band antennas
Wireless Speed*
• 802.11a: 6, 9, 12, 18, 24, 36, 48, 54 Mbit/s
• 802.11b: 1, 2, 5.5, 11 Mbit/s
• 802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mbit/s
• 802.11n (2.4GHz): 6.5 to 300 Mbit/s
• 802.11n (5GHz): 6.5 to 450 Mbit/s
Transmitter Power
• 802.11a:
  19 dBm at 6-36 Mbit/s
  18 dBm at 48 Mbit/s
  16 dBm at 54 Mbit/s
• 802.11b:
  20 dBm at 1, 2, 5.5, 11 Mbit/s
• 802.11g:
  20 dBm at 6-36 Mbit/s
  19 dBm at 48 Mbit/s
  18 dBm at 54 Mbit/s
• 802.11n (2.4GHz):
  HT20
  20 dBm at MCS0-MCS4, MCS8-MCS12
  19 dBm at MCS5, MCS13
  18 dBm at MCS6, MCS14
  17 dBm at MCS7, MCS15
  HT40
  19 dBm at MCS0-MCS5, MCS12-MCS13
  16 dBm at MCS7, MCS15
• 802.11n (5GHz):
  HT20
  19 dBm at MCS0-MCS3, MCS8-MCS11, MCS16-MCS19
  18 dBm at MCS4-MCS6, MCS12-MCS14, MCS20-MCS21
  17 dBm at MCS22
  14 dBm at MCS23
  HT40
  18 dBm at MCS4-MCS5, MCS12-MCS13, MCS20-MCS21
  17 dBm at MCS6, MCS14
  16 dBm at MCS7, MCS15, MCS22
  13 dBm at MCS23
Receiver Sensitivity
• 802.11a:
  -82 dBm at 6 Mbit/s
  -81 dBm at 9 Mbit/s
  -79 dBm at 12 Mbit/s
  -77 dBm at 18 Mbit/s
  -74 dBm at 24 Mbit/s
  -70 dBm at 36 Mbit/s
  -66 dBm at 48 Mbit/s
  -65 dBm at 54 Mbit/s
• 802.11b:
  -87 dBm at 1 Mbit/s
  -87 dBm at 2 Mbit/s
  -85 dBm at 5.5 Mbit/s
  -82 dBm at 11 Mbit/s
• 802.11g:
  -82 dBm at 6 Mbit/s
  -81 dBm at 9 Mbit/s
• 802.11n (2.4GHz):
  HT20
  -82 dBm at MCS0/8
  -79 dBm at MCS1/9
  -77 dBm at MCS2/10
  -74 dBm at MCS3/11
  -70 dBm at MCS4/12
  -66 dBm at MCS5/13
  -62 dBm at MCS6/14
  -64 dBm at MCS7/15
  HT40
  -79 dBm at MCS0/8
  -76 dBm at MCS1/9
  -74 dBm at MCS2/10
  -74 dBm at MCS3/11
  -67 dBm at MCS4/12
  -63 dBm at MCS5/13
  -65 dBm at MCS6/14
  -61 dBm at MCS7/15
• 802.11n (5GHz):
  HT20
  -82 dBm at MCS0/8/16
  -79 dBm at MCS1/9/17
  -77 dBm at MCS2/10/18
  -74 dBm at MCS3/11/19
  -70 dBm at MCS4/12/20
  -66 dBm at MCS5/13/21
  -65 dBm at MCS6/14/22
  -64 dBm at MCS7/15/23
  HT40
  -79 dBm at MCS0/8/16
  -76 dBm at MCS1/9/17
  -74 dBm at MCS2/10/18
  -67 dBm at MCS4/12/20
  -63 dBm at MCS5/13/21
  -62 dBm at MCS6/14/22
  -61 dBm at MCS7/15/23
Security
• WPA & WPA2 (Wi-Fi Protected Access)
• 64/128-bit WEP encryption
• Wi-Fi Protected Setup (WPS) - PIN/PBC
Device Management and Monitoring
• Microsoft Internet Explorer 6+, or Firefox 1.5+, or otherJava-enabled browsers
• D-link Network Monitor Yahoo! Widget
• D-link Internet Usage Meter Yahoo! Widget
• DLNA Server for streaming media to compatible media players*****
SharePort Plus Function Support
• Allows for connection of an external hard drive or multifunction printer to the USB port
• Allows sharing of hard drives, printing, and scanning functions****
QoS
• D-Link Intelligent QoS technology
Advanced Firewall Features
• IP/MAC address filtering
• VPN pass-through / Multi-session PPTP/L2TP/IPSec
• DMZ
Router Features
• Port Forwarding
• Port Triggering / Special applications support
• Static routes support
• WLAN Partition support
• DHCP server
• DNS Relay
Minimum System Requirements
• Windows®7/Vista**/XP SP3 или Mac OS®X(v10.4)***
• Microsoft Internet Explorer 6 or higher, Firefox 1.5 or higher
• CD-ROM
• Ethernet network interface
• Cable or DSL modem
• Subscription with an Internet Service Provider
Çözümler
Sipariş Bilgisi
DIR-835  Wireless N750 Dual Band Router
Görseller
DIR-835A1
Front view
Back view
İndir
Destek Merkezi
