Hızlı Arama
Ürün Özellikleri:
802.11n Wireless Whole Home Router with 4-Port Switch and the port USB, up to 300 Mbit / s
EOL
Tanımlama:
High-speed, reliable connection with other devices
Router D-Link Whole Home provides a secure and high-speed connectivity to wired and wireless devices. The 802.11n standard and unique technology D-Link Smart Beam provide access to the Internet at home or in the office. The router also features a 4-port Gigabit LAN with QoS; just connect wired devices to the ports in order of importance, and the router will automatically configure QoS. It provides a clear picture when watching streaming video on your PC or game console, and view Web-pages or downloading files to your PC without delay. You can also connect a USB-printer or network storage and gain share them via the function SharePort D-Link.
Technology SmartBeam
Using a unique smart antenna D-Link, DIR-645 router automatically adjusts coverage to optimize the connection each authorized wireless client. This extends the range of network coverage and minimize interference, provides high-speed connections, and even save power by adjusting the amount of power used for wireless connections.
Double the wireless coverage
Compared with the standard antenna multiple antennas Router DIR-645 provides double the wireless coverage and eliminate "dead zones". Connect the device at a distance and enjoy a stable network connection - inside, outside, around, and even on different floors of the house.
Safety and reliability
WPA/WPA2 encryption protocols prevent unauthorized access to the network. You can also customize the guest areas to provide limited network access to individual wireless devices, and create a schedule, it allows you to turn the wireless network, if you are away from your home or office.
Ürünler | Destek  | Haberler  | Hakkında |
