DIR-457EOL EOS
MyPocket 3.5G HSDPA Router
Tanımlama
WIRELESS NETWORKING ON THE GO
The D-Link myPocket 3.5G HSDPA Router allows users to access worldwide mobile broadband networks. Once connected, users can enjoy data transmission and media streaming on-the-go. Simply insert your UMTS/HSDPA SIM card, and share your 3.5G Internet connection through a secure 802.11g wireless network.
Multifunctionality
The D-Link myPocket 3.5G HSDPA Router can be configured to work as a Wi-Fi Router or 3.5G Modem with the flip of a switch. Share 3.5G connectivity with your colleagues or family while travelling or at work. Connect the D-Link myPocket 3.5G HSDPA Router to a PC to enjoy personal access to the Internet.
ADVANCED NETWORK SECURITY
Keep your wireless network safe with WPA/WPA2 wireless encryption. The DIR-457 utilizes a built-in firewall to prevent potential attacks across the Internet.
SIMPLE TO INSTALL AND USE
The 3.5G HSDPA Router can be installed quickly and easily almost anywhere. This router is great for situations where an impromptu wireless network must be set up, or wherever conventional network access is unavailable.
Genel Özellikler
GSM BAND (GSM/GPRS/EDGE)
• 850 / 900 / 1800 / 1900 MHz
• Power Class 4 (+33dBm, 850 / 900 MHz)
• Power Class 1 (+30dBm, 1800 / 1900 MHz)
UMTS/HSUPA BAND *
• 850 / 1900 / 2100 MHz
• Power Class 3 (+24dBm)
DATA THROUGHPUT **
• Downlink up to 7.6Mbps in HSUPA mode
• Uplink up to 5.76Mbps in HSUPA mode
• Max. 54Mbps in 802.11g mode
Standards
• 802.11b
• 802.11g
• 802.3
• 802.3u
Wireless Security
• 64/128-bit WEP
• WPA-PSK & WPA2-PSK
• WPS-PIN
• Built-in firewall
VPN
• L2TP/PPTP/IPSec VPN Pass-through
Advanced functions
• Storage file sharing
• UPnP
• Port Forwarding
ANTENNA
• 3 Internal antennas
CARD SLOTS
• Standard 6-pin SIM card interface
• Micro-SD card interface
LED Status Indicators
• Power Status
• Signal Status
Çözümler
Sipariş Bilgisi
DIR-457  MyPocket 3.5G HSDPA Router
Görseller
DIR-457A1
Back view
Front view
İndir
Destek Merkezi
