Hızlı Arama
Ürün Özellikleri:
High-Speed 2.4GHz(802.11g) Wireless PCI Adapter
Tanımlama:
Up to 54Mbps Wireless Speed
The DWL-G510 network card provides speeds of up to 54Mbps when used with other 802.11g equipment. This enhanced speed and adoption of 2.4GHz frequency, now available for public use in most countries, plus the mobility and convenience inherent in a wireless LAN, make this network card an ideal solution for bandwidth intensive wireless applications for your computer.
Easy Migration to Higher Bandwidth
The DWL-G510 network card is backward compatible with 802.11b standard wireless devices, providing seamless interoperability with the earlier standard equipment. By maintaining compatibility with your existing wireless network equipment, this network card lets you upgrade to a higher speed while protecting your past investments in networking.
Network Security
Easy Installation
The DWL-G510 network card features WPA (Wi-Fi Protected Access) and 802.1x for wireless user authentication, providing you a much higher level of security for your data and communications. It also includes a configuration utility to let your computer discover available wireless networks and create and save detailed connectivity profiles for the networks most often accessed.
Easy Installation
With PCI plug-and-play capabilities, this network card can be easily installed into your PC for direct connection to any wireless device in the ad-hoc mode or through an access point or router in the infra-structure mode. When used with other D-Link AirPlusG products, the network card automatically connects to the network.
Ürünler | Destek  | Haberler  | Hakkında
