DWL-1040AP+EOL EOS
Tanımlama
Built-in Bridge and Repeater Functions
The DWL-1040AP+ can be configured to operate in any one of the 5 modes: (1) as a wireless access point, (2) a point-to-point bridge with another access point, (3) a point-to-multi-point wireless bridge, (4) a wireless client, or (5) a wireless repeater. With the built-in bridge and repeater functions, the DWL-1040AP+ gives you the flexibility to configure the device to meet your environment's requirements.
Advanced Features
In access point mode, the DWL-1040AP+ offers a load-balancing feature that maximizes the wireless bandwidth available to wireless clients by sharing the load within a group of access points. Additionally, the DWL-1040AP+ provides a redundancy feature to allow it to be configured to backup a primary access point. These advanced features makes the DWL-1040AP+ an ideal solution for hotspot deployments and creating/extending wireless local networks in offices or other workplaces.
Range Extension
With its repeater mode, the DWL-1040AP+ extends the range of your wireless LAN network with interoperation with D-Link AirPlus DWL-900AP+, DI-614+, DI-714P+, AirPro DI-764 and DI-754 (with inserted DWL-650+).
Enhanced Speed Transmission
At 22Mbps, the DWL-1040AP+ delivers high data transfer rate within the industry standard. This speed is double the 11Mbps normally found in other 2.4GHz wireless LAN Access Points.
Industry-standard Interoperability
The DWL-1040AP+ delivers speeds without compromising compatibility. With both WiFi and IEEE 802.11b wireless LAN industry standard compliance, the DWL-1040AP+ provides you with excellent network interoperability.
Network Security
The DWL-1040AP+ provides the necessary security, using the enhanced 64/128/256-bit industry-standard WEP (Wired Equivalent Privacy) encryption protocol. Data privacy mechanism is based on a shared key algorithm, as described in the wireless LAN standard. The DWL-1040AP+ supports 802.1x authentication for protection against network intrusion. Used in conjunction with a RADIUS server, this function provides a means to verify the identity of the client before an access to the network is granted.
Embedded DHCP Server
The DWL-1040AP+ includes an embedded DHCP server that once enabled will automatically assign IP addresses to wireless clients. This unique feature makes the DWL-2000AP an ideal solution for quickly creating and extending a wireless local area network (WLAN) in offices or other workplaces, and at trade shows and other special events.
Genel Özellikler
Standards
- 802.11b+, IEEE 802.11b wireless LAN
- IEEE 802.3 10BASE-T Ethernet
- IEEE 802.3u 100BASE-TX Fast Ethernet
Frequency Range
2.4 - 2.4835 GHz
Operating Channels
- North America (FCC): 11
- Canada (DOC): 11
- Europe (ETSI): 13
- Japan (MKK): 14
Radio & Modulation Technology
- Packet Binary Convolution Coding (PBCC)
- Direct Sequence Spread Spectrum (DSSS)
- 11-chip Barker sequence
Modulation Techniques
- 22Mbps/8.5db: PBCC
- 11Mbps/8.5db: CCK
- 11Mbps/4.5: PBCC
- 5.5Mbps/5.5db: CCK
- 5.5Mbps/1.5db: PBCC
- 2Mbps/3db: Barker
- 1Mbps/0db: Barker
Data Rates
- 22 Mbps
- 11 Mbps
- 5.5 Mbps
- 2 Mbps
- 1 Mbps
- Auto fall-back
Antennas
Dual 2dBi Gain dipole detachable antennas with reverse SMA connectors
Transmitter Output Power
17dBm +/- 2dBm
Reception Sensitivity
- 22Mbps: 10-5 BER @ -80dBm minimum
- 11Mbps: 10-5 BER @ -79dBm minimum
- 5.5Mbps: 10-5 BER @ -83dBm minimum
- 1Mbps: 10-5 BER @ -89dBm minimum
Software
Operating Range *
- Up to 100 m (328 feet) indoor
- Up to 400 m (1,312 feet) outdoor
* Environmental factors may adversely affect operation range
Wireless LAN to Ethernet Interface
4 RJ-45 10/100Mbps Fast Ethernet switch ports
Diagnostic LEDs
- Power/Status
- Diagnostic
- Wireless
- Ethernet
Operating Modes
- Access Point
- Access Point to Access Point bridging
- Access Point to multi-point bridging
- Wireless client
- Repeater
Roaming
Among Access Points on the same subnet
IP Number Assignment
Automatic through built-in DHCP server
Security
- Data encryption: 64-bit, 128-bit, 256-bit WEP (Wired Equivalent Privacy)
- 802.1x authentication access control
Configuration & Management
- Manage wireless LAN, network connection and client access control through web browser (Java Script supported)
- Access Point Manager
- TFTP client for firmware upgrade
- Set IP session (ARP/ping)
- DHCP client (IP number self-assignment)
Çözümler
Sipariş Bilgisi
802.11b+ Wireless LAN Access Point
DWL-1040AP+ With 4 built-in 10/100Mbps switch ports
