Hızlı Arama
Ürün Özellikleri:
Central wifi Manager (Soft Controller)
Tanımlama:
Features
Web-based management
  • Software controller that can be installed on a Microsoft Windows computer and accessed through any device with a web browser such as a smartphone, tablet or computer
Multi-site management
  • Multiple distributed sites can be managed from a central location
  • The multi-tenant architecture provides multi-layer management authority
NAT pass-through
  • Controllers can manage wireless access points in remote locations even if they are behind a NAT device (router or firewall)
Captive portal and access control
  • Supports local DB, external RADIUS, LDAP, POP3 and Wi-Fi passcode authentication
  • Supports user access control
  • Customisable captive portal login page
Auto radio frequency (RF) management
  • Supports automatic channel and output power optimisation
  • Wireless radio on/off by scheduling
Bandwidth optimisation
  • Optimises wireless bandwidth
Compatible with
  • DAP-2230 - Wireless N PoE Access Point
  • DAP-2310 - Wireless N Access Point
  • DAP-2360 - Wireless N PoE Access Point (plenum-rated)
  • DAP-2660 - Wireless AC1200 Simultaneous Dual-Band PoE Access Point
  • DAP-2690 - Wireless N Simultaneous Dual-Band PoE Access Point
  • DAP-2695 - Wireless AC1750 Simultaneous Dual-Band PoE Access Point
  • DAP-3320 - Wireless PoE Outdoor Access Point
  • DAP-3662 - Wireless AC1200 Simultaneous Dual-Band Outdoor PoE Access Point
WLAN Management
Maximum APs per Device (Controller)
  • 5003
WLAN Management Features
  • AP grouping
  • Multi-tenancy
  • Visualised topology
  • NAT pass-through
AP-Controller Connection Mode
  • Bridge mode
User Authentication
Guest Portal
  • Captive portal with customisable login page
Authentication Method
  • Local
  • POP3
  • RADIUS
  • LDAP
  • Voucher
Hotspot Features
  • Built-in support for voucher-based authentication
  • Built-in hotspot manager for voucher creation and guest management
  • Rate limiting and bandwidth control for guest and hotspot portal
Wireless Features
RF Management and Control
  • Auto Output Power Control
  • Auto Channel
  • Self-healing around failed APs
Multiple SSIDs per Radio(AP)
  • 8
Advanced Wireless Features
  • Band steering
  • L2 roaming
  • Bandwidth optimisation
WIDS System
  • Rogue AP detection
System Management
Management Interface
  • Web-based user interface
Minimum System Requirements
  • Computer running Microsoft Windows 7 or Windows Server 2008/2012
Online Check
  • Firmware
  • Module
Scheduling
  • Firmware update
  • Configuration update
Wireless Access Points Compatible with Central WiFiManager
DAP-3662
  • Support dual-band 802.11ac/n/g/b/a
  • Outdoor deployment (IP68)
  • 900 Mbps 5GHz speed
  • 300 Mbps 2.4 GHz speed
  • Up to 16 SSID
  • 2 x Gigabit Ethernet
  • Supports 802.3af PoE
  • Internal antenna
  • Wall or pole-mountable
DAP-3662
  • Support 802.11n/g/b
  • Outdoor deployment (IP55)
  • Up to 8 SSID
  • 1 x Fast Ethernet
  • Internal antenna
DAP-2695
  • Indoor deployment
  • 1300 Mbps 5GHz speed
  • 450 Mbps 2.4 GHz speed
  • Up to 16 SSID
  • Supports 802.3at PoE
  • External antenna
  • Wall-mountable or desktop placement
DAP-2660
  • Indoor deployment
  • Up to 16 SSID
  • 1 x Gigabit Ethernet
  • Internal antenna
  • Wall/ceiling-mountable or desktop placement
DAP-2690
  • Support dual-band 802.11n/g/b/a
  • Indoor deployment
  • 300 Mbps 5GHz speed
  • Up to 16 SSID
  • External antenna
DAP-2360
  • Support single-band 802.11n/g/b
  • Indoor deployment
  • Up to 8 SSID
  • External antenna
DAP-2310
  • Indoor deployment
  • Up to 8 SSID
  • External antenna
DAP-2230
  • Indoor deployment
  • Up to 8 SSID
  • 1 x Fast Ethernet
  • Internal antenna
1 Supported models: DAP-3662, DAP-3320, DAP-2695, DAP-2660, DAP-2690/B1, DAP-2360/B1, DAP-2310/B1, DAP-2230
2 Supported Operating Systems: Microsoft Windows 7 or Windows Server 2008/2012
3 Number of wireless access points supported depends on the specification of the computer on which Central WiFiManager is installed. To support 500 APs, a computer with at least an Intel Core i5 3.2 GHz with 4 GB RAM and 2 TB hard drive is recommended.
Ürünler | Destek  | Haberler  | Hakkında |
