Hızlı Arama
Ürün Özellikleri:
Kablosuz Dual-Band Repeater AC750
Tanımlama:
Wireless Dual-Band Repeater AC750 DAP-1520 is a portable device that increases the range of the existing network. The device can be placed anywhere in your home. Compact, fits in the palm repeater DAP-1520 has a high capacity and supports wireless networking speeds of up to 300 Mbit / s in the 2.4 GHz band and up to 433 Mbit / s in the range of 5GHz,
The coverage of a wireless network
Wireless Dual-Band Repeater AC750 DAP-1520 allows you to extend wireless coverage 802.11ac. Operation in 5 GHz helps reduce noise emanating from a nearby transmitter and the use of the 2.4 GHz band provides backwards compatibility with older wireless devices on the network, allowing high-speed and reliable wireless connection.
Easy to install and use
Installing repeater DAP-1520 is not difficult. You can use the application QRS Mobile, mobile devices supported on the platform iOS or Android, to install a repeater without using a computer. You can configure the one-touch WPS button on the DAP-1520 and the router or access point coverage which should be increased, and repeater DAP-1520 will be adjusted automatically. You can also use the Setup Wizard, which allows to configure a wireless manner via a PC or mobile device.
Compact, user-friendly design
Compact device DAP-1520 is ideal for use at home or in a small office, because it does not take up much space and is ready for operation immediately after connection. His small wall close coupled design is ideal for connecting to a power outlet without obscuring other outlet is located near, and eliminates the need to use the power cord. Neat appearance of the device allowing it to fit into the interior of the house or office.
Ürünler | Destek  | Haberler  | Hakkında |
