Hızlı Arama
Ürün Özellikleri:
Antenna extension cable with connectors RP-N Plug and N Plug, 1m
Genel Özellikler:
Fiziksel Özellikler
Frequency range
2.4 ~ 6 GHz
VSWR
1.7:1 max. at 2.4 GHz
2.7:1 max. at 5 GHz
The insertion loss
0.8 dB max. at 2.4 GHz
2 dB max. at 5.15 ~ 5.85 GHz
Resistance
50 ohms
Type of cable
CFD-200
Cable Length
1 m
Jack
RP-N Plug, N Plug
Antenna Structure
Collinear
The physical parameters
Temperature
-40 To 70 ° C
Humidity
95% at 55 ° C
Standard dust and moisture protection
IP67
Weight
199 g
Measurements
1030 x 20.9 x 20.9 mm
Ürünler | Destek  | Haberler  | Hakkında |
