Hızlı Arama
Ürün Özellikleri:
Dual-band Wi-Fi 802.11n (2.4/5GGts) Mediamost, up to 300 Mbit / s
Tanımlama:
High-speed wireless bridge
DAP-1513 is a dual-band high-speed wireless bridge that can transmit data at speeds up to 300 Mbit / s with support for Wireless N technology and 2x2 MIMO. Mode of the device - the bridge (bridge): works the same as "wireless client", but provides simultaneous access to the network for multiple devices connected using Ethernet-cable (as opposed to the regime, "wireless client"). Ability to connect to the DAP-1513 computers, set-top boxes or game consoles to access the wireless network makes it ideal for online games, watching streaming HD-video, listen to music, share photos and files.DAP-1513 can function as a base station for connecting to a wireless network device of the standards 802.11a, 802.11b, 802.11g and 802.11n.
Dual Band for secure connections
DAP-1513 supports dual band (the ability to select the desired frequency range of 2.4 GHz or 5 GHz). 5 GHz band can be used for streaming video and online games. The 2.4 GHz is compatible with various devices: DAP-1513 can be connected to any wireless network operating in the 2.4 GHz band.
Simple and safe setting
WPA/WPA2 encryption protocols prevent unauthorized access to network traffic. Use the Wi-Fi Protected Setup (WPS) on the DAP-1513 to automatically configure and wireless security. This allows you to view web-sites and make purchases in the Internet without fear that unauthorized users can not view wireless traffic.
Port-based QoS
DAP-1513 supports port-based QoS, allowing you to set the priority of the connected devices by simply connecting them to the appropriate port. For example, you can connect the cable box to the port with the highest priority and to ensure that the transmission of video over the Internet is no delay, even when there is a file download to a computer
Ürünler | Destek  | Haberler  | Hakkında |
