Hızlı Arama
Ürün Özellikleri:
Gigabit Ethernet port Powerline Adapter
Genel Özellikler:
Fiziksel Özellikler
Powerline Interface
Power connector (depending on country)
Ethernet Interface
RJ-45 connector
Standards
• IEEE 802.3
• IEEE 802.3u
• IEEE 1901
• HomePlug AV2
Safety
128-bit AES data encryption
Indicators
• Power
• Ethernet
• Powerline
The modulation scheme Powerline
Symbol OFDM modulation
Bandwidth Powerline
From 2 MHz to 70 MHz
Data rate
• Ethernet: 10/100/1000 Mbit / s
• PowerLine: up to 600 Mbit / s (PHY rate) 2
Fiziksel Özellikler
Measurements
87,47 x 62,2 x 30 mm
Weight
90 grams
Power Input
100-254 VAC, 50/60 Hz
Power consumption
Max. 3.7 W
Temperature
• Operating: 0 to 40 C
• Storage: -20 to 65 C
Humidity
• Operating: 10% to 90% (non-condensing)
• Storage: 5% to 95% (non-condensing)
Certifications
• CE
• FCC
• UL
• CE / LVD
Ürünler | Destek  | Haberler  | Hakkında |
