DHP-1565EOL EOS
Wireless 802.11n Gigabit Router PowerLine, up to 500 Mbit / s
Tanımlama
The use of power lines as high-speed network cables
Wireless 802.11n Gigabit Router PowerLine D-Link DHP-1565 uses the household power circuit for the deployment of the network throughout the area of ​​the house at a rate of up to 500 Mbit/s1. Simply connect the router to the Internet and connect the power cord to an electrical outlet. Power Cable Router DHP-1565 will now transmit on the network wiring to any device that supports the HomePlug AV standard and is connected to any other electrical outlet. This avoids network cables throughout the house and to deploy a network in those places where the wireless signal is not available.
Working in the router and access point
DHP-1565 can operate in two modes - router mode and access point mode. In the DHP-1565 router connected to a cable or DSL-modem to share the Internet connection of all devices on the Ethernet-cable, Wi-Fi or through wiring (a network of "PowerLine").In access point mode, DHP-1565 functions as a coupling device between the router and the devices connected to the DHP-1565 and a cable or Wi-Fi.
Protect your network with a single button click
AES data encryption protects the PowerLine network from unauthorized access or interception of data, and advanced encryption standards such as WEP, WPA and WPA2, and ensure the safety of data during transmission over a wireless channel. Click the Common Connect, to establish a secure connection to Wi-Fi (via WPS) or PowerLine just a few seconds. Built-in dual active firewalls (SPI and NAT) prevents potential attacks from across the Internet.
Save energy with the help of technology D-Link Green
DHP-1565 supports D-Link Green, which includes features such as a schedule of inactivity Wi-Fi networks, energy saving PLC (power line communications) and energy savings, depending on the status of the connection. Schedule Wi-Fi allows you to set specific times when the wireless network is turned off to save energy and protect against unauthorized access. Energy savings PLC releases the connection when no activity PowerLine Ethernet or wireless connection. Energy savings, depending on the connection status automatically detects the link status of wired devices and reduces the power consumption on inactive ports. These features help to save energy without sacrificing performance.
Genel Özellikler
Çözümler
Sipariş Bilgisi
Görseller
DHP-1565/Ax
Front view
Back view
İndir
Destek Merkezi
