DCS-3511
HD-Video Camera with PoE
Tanımlama
HD-Camera D-Link DCS-3511 is equipped with a 1-megapixel CMOS-sensor with progressive scan and varifocal lens with 2.8-12 mm focal length. The camera enables you to capture HD-video with a resolution up to 1280x800 at up to 30 frames per second. You can save snapshots and videos on a network drive or on SD-card connected to the camera.
High-resolution video monitoring
Built-megapixel sensor produces snapshots and video quality with resolution up to 720p, providing high-definition video capture with all the details. Functions ePTZ provide digital zoom in / zoom out the video, and pan the image obtained from the camera.Thus, it is easy to monitor a large area. Support for Power over Ethernet (PoE) allows you to install the camera in locations where power outlets are not available.
Support for multiple video streams
To increase bandwidth efficiency and increase the image quality camera DCS-3511 uses the simultaneous streaming of video formats MJPEG, MPEG-4 and H.264. In addition, the camera can organize multicast data streams and provide access to video on demand.
Complete solution for conducting surveillance
Camera DCS-3511 is a complete solution for surveillance, providing snapshots and record video to MicroSD-card, eliminating the need to use a computer or network storage device. To enhance the video surveillance package includes free software D-ViewCam, designed to control the 32 cameras with a wide range of functions, such as viewing the images from multiple cameras at the same time and send to e-mail notifications of suspicious events or emergency situations.
Genel Özellikler
Çözümler
Sipariş Bilgisi
Görseller
DCS-3511/Ax
Back view
View from the right
Left side view
İndir
Destek Merkezi
