DCS-6915EOL EOS
Full HD High Speed Dome Camera with 20x optical zoom
Tanımlama
Full HD Dome Camera D-Link DCS-6915 is the ideal solution for creating a system of professional high-definition video, and security of small, medium and large enterprises. 3-megapixel CMOS-sensor with progressive scan produces superb image quality at resolutions up to 1080p. The powerful 20x optical zoom and 8x digital zoom provides the ability to easily see even the smallest details.
Proportional speed control tilt, pan and zoom
Speed control of pan and tilt allows you to easily and accurately adjust the field of view of the camera. When using the zoom function, the speed of rotation is automatically slowed to improve visibility and control. PTZ preset point tracking allows the camera to perform in a predetermined way.
The efficiency under all weather conditions
Designed to work in harsh conditions, the camera DCS-6915 is made in a metal vandal-resistant (standard IK-10) and weatherproof (IP-66 standard) package that is able to withstand different kinds of impact and protect your camera under adverse weather conditions. Support for Power over Ethernet simplifies installation of the device through the transfer of power and network connectivity, one Ethernet-cable. With a built-in heater and fan chamber can operate over a wide temperature range (from -40 ° C to 50 ° C).
Wide Dynamic Range (WDR)
Video Camera DCS-6915 with the WDR sensor delivers excellent image quality in a non-uniform illumination, thus allowing to identify the subject lit from behind, or shooting in very bright light. The camera can be successfully operated in areas with contrast lighting. For example, installing indoor DCS-6915 does all the settings to adapt to the intensity of the sunlight falling through the window. Thanks to the combination of these functions camcorder is the ideal solution for a variety of video surveillance systems.
Adjustable low-pass filter for continuous monitoring
The work of the infrared filter (ICR filter) can be adjusted manually or set to automatically adjust depending on lighting conditions.This feature allows the camera to capture crisp color images during the day and black-and-white pictures in low light.
Reliable management software
As with the camera DCS-6915 includes D-ViewCam - software for video surveillance systems, allowing you to view images, manage, and to record up to 32 cameras on a single computer. In addition, you can enable email alerts when motion is detected or when the signal on the digital input.
