DNR-322LEOL EOS
Network Video Recorder (NVR) with two drive bays and support service mydlink
Tanımlama
Convenient and reliable video recording
Network Video Recorder DNR-322L - a stand-alone storage device that allows you to record video from several (up to nine) cameras in the allotted space of hard drives, eliminating the need to turn on the computer. Thanks to technology mydlink DNR-322L provides remote monitoring and playback via Web-browser on the mydlink website or through a Web-based NVR. Video Recorder DNR-322L can continue to record video, while a user is viewing a video or searches. Thanks to a set of management functions videos DNR-322L is a convenient and effective solution.
Multifunctional surveillance system
Users are provided with a wide range of options for viewing and organizing video on the screen. In a system with multiple channels, users can simply drag and drop selected cameras to the viewing area. Names of cameras and recording status are displayed on the screen. You can view the video from a single camera in full screen mode with two-way transmission of sound. Users can control PTZ (pan / tilt / zoom), using the interface or by directly clicking on the video.
Secure data storage
Administrators can filter the external connections to the NVR by IP-address, limiting access and thus increasing security.Administrators can also assign access rights to users by clicking the camera, which will be allowed access. Periodically or when necessary, you can save the recorded data to the add-on storage. NVR also supports an option to protect data using a RAID 1 configuration that duplicates the data recorded on two different disk. In the event of failure of one of the hard drives data is stored on the second drive. Also, a second hard disk drive can be operated under the file server is installed on Windows as a network drive.
Advanced features video
Intuitive interface DNR-322L can easily configure options such as compression codec, resolution and frame rate for all connected cameras. After installing the camera can perform continuous recording or recording on a schedule set by the user.NVR also provides a record based on certain triggering events, such as when motion is detected.
Genel Özellikler
Çözümler
Sipariş Bilgisi
Görseller
DNR-322L/Ax
Front view
Back view
İndir
Destek Merkezi
