Hızlı Arama
Ürün Özellikleri:
Network Video Recorder (NVR) with two drive bays and support service mydlink
Genel Özellikler:
Fiziksel Özellikler
Software
The Linux operating system
Supported Cameras
Supports all network cameras D-Link. It also supports automatic detection and resolution of up to 3 megapixels.
Recording characteristics
• Max. performance (only NVR):
  + H.264 1080P (data rate): 90 Mbit / s
  + H.264 720P (data rate): 90 Mbit / s
  + MJPEG 1080P (fps): 90 fps
  + MJPEG 720P (fps): 192 fps
• Max. performance (NVR + file server):
  + H.264 1080P (data rate): 68 Mbit / s
  + H.264 720P (data rate): 68 Mbit / s
  + MJPEG 1080P (fps): 70 fps
  + MJPEG 720P (fps): 150 fps
Camera Search
UPnP
Record audio and video
Simultaneous recording of audio and video
Compression Format
H.264, MPEG-4, M-JPEG (for the camera)
Video settings
Resolution, quality, frame rate, audio switching, switching to the camera interface
Record Type
• Scheduled recording, manual or event-
• Motion detection recording
Mode of remote viewing live video
• Support for remote viewing via Internet Explorer (max. number of channels - 9)
• Portal mydlink (Max. number of channels - 1)
Managing a remote video viewing in real time
Video in real time, preset (presets) / go (go), patrol, focus, function PTZ, snapshot, full screen mode, digital zoom, e-map, Simultaneous display (1/4/6/9/16/25 / 36/48) channels
Controlling the remote playback
Playing with the functions of a conventional rewind, fast forward / rewind and step forward / rewind
Remote Playback
• Play through Internet Explorer and NVR-client
• Playback system with timeline, search by event, area, cameras, date and time
• IE and NVR-client support playback of a single channel
• The digital zoom
Function Overwrite (overwrite)
Automatic overwrite in case of filling the space on your hard drive
Export Files
• Export video to AVI or ASF
• Export images to BMP and JPG
User Account
Creating additional accounts to allow the user access to the system, and set the authorization for camera channels, PTZ, etc.
The system time
Setting the system time (D-Link NTP, input time manually synchronizing with your computer, the mode of daylight saving time)
DDNS
Support DDNS-Server D-Link
Remote Backup
• Remote software can create a backup copy of the raw data on the secondary storage device
• Automatic backup of videos from previous days to FTP-server
System Status
• Camera status, system status
• Support for EMAP
Network Protocols
• IPV4, ARP, TCP, UDP, ICMP
• DHCP-Client
• NTP-Client (D-Link)
• DNS-client
• DDNS-Client (D-Link)
• SMTP-client
• HTTP-server
• PPPoE
• UPnP
• Filtering IP-addresses
User interface
• Web-portal Mydlink - Internet Explorer v6 or higher
• HTTP Web-browser - Internet Explorer 7 or higher (32 bit)
• NVR Search Utility
Hardware Specifications
Standards
• IEEE 802.3/u/z
• Auto MDI / MDI-X
• SATA I, II
HDD (Hard Disk Drive) 1
• Monitor your hard drive and control via computer
• Reformatting the hard drive
• RAID 0 2
• RAID 1 2
• JBOD
Two reset mode
• Reset via Web-based interface
• Reset with the button on the body (hold for 5 seconds)
Flash ROM
128 MB
RAM
128MB DDR II
Network interface
LAN-port Gigabit Ethernet (10/100/1000 Mbit / s)
I / O Ports
• RJ-45 port
• DC-in jack
• USB-port for UPS status update (optional)
Fiziksel Özellikler
Power consumption
• Max. Power consumption: 25.20 W
• Max. Power consumption in standby: 0,23 W Power Power Supply 12V, 4A
Measurements
115 x 146.4 x 178.5 mm
Weight
0,875 kg
Operating temperature
0 ˚ to 55 ˚ C
Storage temperature
From -20 ˚ to 70 ˚ C
Humidity
From 5% to 90% (non-condensing)
Certifications
• CE
• FCC
• RoHS
Scope of delivery
• Video Recorder NVR
• Power Adapter
• Ethernet cable
• Quick Installation Guide
• Clip cord
• CD-ROM c:
  + Software
  + Product documentation
1 Hard disks are not included.
2 For mirroring RAID 0 and RAID 1 requires the use of two internal drive SATA. In order to avoid incompatibility in RAID 1 operation, use disks of the same manufacturer. Formatted space on the hard disk depends on the disk space smaller. Earlier versions of the SATA drive may not be compatible. List SATA, HDD, compatible with NVR D-Link, is available on the Web-site D-Link.
Ürünler | Destek  | Haberler  | Hakkında |
