Hızlı Arama
Ürün Özellikleri:
802.11n Wireless Camera with IR LED and support for the H.264 video codec and service mydlink
Genel Özellikler:
Fiziksel Özellikler
System Requirements
• Operating System: Microsoft Windows XP, Vista, Windows 7
• Internet Explorer 6 or higher, Firefox 3.5 or higher, Safari 4 or later
Network Protocols
• IPV4, ARP, TCP, UDP, ICMP
• DHCP-Client
• NTP-Client (D-Link)
• DNS-client
• DDNS-client (DynDNS and D-Link)
• SMTP-client
• FTP-client
• HTTP-server
• PPPoE
• UPnP Port Forwarding
• LLTD
Built-in network interface
• 10/100BASE-TX Fast Ethernet
• 802.11b/g/n WLAN
Wireless Security
Data encryption protocols WEP/WPA/WPA2
The output power of the transmitter
16 dbm for 11b, 12 dbm for 11g, 12 dbm for 11n (typical)
SDRAM memory
128 MB
Flash-Memory
16 MB
Support for video compression algorithms
• H.264
• MJPEG
• JPEG for still shooting
Video Properties
• Adjustable image size and quality
• Time stamp and text
• Rotating and mirroring
Video Resolution
640 x 480, 320 x 240,160 x 120 and 30 frames / s
Lens
Focus: 3.15 mm, F2.8
Sensor
1/5 inch VGA CMOS-sensor
Minimum illumination
1 lux@F2.8 with IR LED
Viewing angles
• Horizontal: 45.3 °
• Vertical: 34.5 °
• Diagonal: 54.9 °
Digital Zoom
Up to 4x
Backlight
Infrared light: lighting range up to 5 meters
3A Control
• Automatic Gain Control (AGC)
• Automatic White Balance (AWB)
• Automatic electronic shutter (AES)
Fiziksel Özellikler
Nutrition
• Input: 100-240 VAC, 50/60 Hz
• Output: 5 VDC, 1.2 A
• External switching power adapter AC / DC
Dimensions (W X D X B)
• With bracket and stand: 65.8 x 65 x 126 mm
• Only Camera: 27.2 x 60 x 96 mm
Weight
76.9 g (without bracket and stand)
The maximum power consumption
5.5 W
Operating temperature
0 ˚ C to 40 ˚ C
Storage temperature
From -20 ˚ C to 70 ˚ C
Humidity
20-80% RH non-condensing
EMISSION (EMI), SAFETY and other certificates
• FCC Class B
• IC
• C-Tick
• CE
Ürünler | Destek  | Haberler  | Hakkında |
