Hızlı Arama
Ürün Özellikleri:
3 m KVM cable with VGA and USB
Tanımlama:
The DKVM-CU3 3 m KVM cable allows you to connect your PC to the D-Link DKVM-4U/C KVM switch. The cable has one USB Type-A connector for connecting to the USB Type-A port on your PC and two 15-pin HDB connectors for connecting to the VGA port on your PC and on the KVM switch.
The DKVM-CU3 combines several cables in one assembly, thus allowing you to save space on your table.
Ürünler | Destek  | Haberler  | Hakkında |
