Hızlı Arama
Ürün Özellikleri:
Industrial Layer 2 switch with 10 10/100 / 1000Base-T ports and 2 1000Base-X SFP ports (8 ports with PoE support 802.3af / 802.3at (30W), PoE budget up to 240W)
Genel Özellikler:
Fiziksel Özellikler
Hardware
CPU
• Vitesse VSC7425 (416 MHz)
• Microsemi PD69208M + PD69200 (PoE)
RAM
• 128 MB
Flash Memory
• 32 MB
Interfaces
• 10 10/100 / 1000Base-T ports (8 ports with PoE support)
• 2 ports of 1000Base-X SFP
• Console port with RJ-45 connector
• Relay output 1 A / 24 V for power failure notification
Indicators
• PWR 1/2/3
• ALM
• SYS
• Link / Activity / Speed ​​(per port)
• PoE status
• Power budget PoE
Buttons
• Reset button
Power connector
• DC: terminal block for connecting up to two independent power supplies 1
(46 V to 54 V DC)
• AC: 4 pin power mini-DIN PD-40VS (for connecting the power adapter 1 with the PDP-40 plug)
Housing
• Metal housing (IP30 standard)
Functional
Standards and functions
• IEEE 802.3 10Base-T (copper twisted pair)
• IEEE 802.3u 100Base-TX (copper twisted pair)
• IEEE 802.3ab 1000Base-T (copper twisted pair)
• IEEE 802.3z 1000Base-X
• IEEE 802.3x Flow Control
• Automatic detection of MDI / MDIX on all copper ports
Performance
Switching matrix
• 24 Gb / s
Switching Method
• Store-and-forward
MAC address table size
• 8K entries
Max. the speed of redirection of 64-byte packets
• 17.85 Mpps
Package Buffer
• 4 MB
Jumbo frame
• 9,216 bytes
Software
Layer 2 functions
• Flow control
   - 802.3x
   - Preventing HOL locks
• IGMP Snooping
   - IGMP v1 / v2
   - IGMP v3 2
   - Support for 64 groups
   - IGMP Snooping Querier
• MLD Snooping
   - MLD v1
   - MLD v2 2
   - MLD Snooping Querier
• Link aggregation
   - 802.3ad
   - Max. 6 groups per device / 8 ports per group
• Support for Ethernet Ring Protection Switching (ERPS 2 , ITU-T G.8032)
• Loopback Detection
• LLDP
• Port mirroring
   - Support for 1 group of mirroring
   - Modes: One-to-One, Many-to-One
• Statistics
   - Tx Ok
   - Tx Error
   - Rx Ok
   - Rx Error
• Spanning Tree Protocol
   - 802.1D STP
   - 802.1w RSTP
   - 802.1s MSTP 2
VLAN
• 802.1Q Tagged VLAN
• Port-based VLANs
• Auto Surveillance VLAN 2.0 (ASV2.0) 2
• Voice VLAN
• Asymmetric VLAN
• VLAN Groups
   - 128 VLAN groups
   - Max. 4094 VLANs
• GVRP 2
Quality of Service (QoS)
• CoS based on:
   - Switch Ports
   - 802.1p priority queues
   - ToS
   - IP Precedence
• Bandwidth management
   - Based on the port (incoming, with a minimum step of up to 64 Kbps)
• Queue processing
   - Strict Priority
   - Weighted Round Robin (WRR)
• 4 queues per port
AAA
• Web-based access control (WAC) 2
• 802.1X authentication 2
• RADIUS 2
Security
• D-Link Safeguard Engine
• Segmentation of traffic
• Broadcast / Multicast / Unicast Storm Protection
• Preventing DoS attacks
• SSL
• Port Security
OAM
• Cable Diagnostics
• Dying Gasp 2
• DDM digital monitoring function (Digital Diagnosics Monitoring) 2
Control
• Web interface (support for IPv4 / IPv6)
• D-Link Network Assistant (DNA)
• Command line interface (CLI)
• SNTP
• SNMP v1 / v2c
• SNMP v3 2
• SNMP Trap
• Telnet server
• System log
• DHCP client
• TFTP client
• LLDP
• D-Link Discovery Protocol (DDP)
• Support for multiple software versions
• Support for multiple versions of configurations
Technology Green
• Energy saving due to:
   - Connection Status Definitions
   - Turn off indicators
   - Turn off the ports
   - Using sleep mode
MIB / RFC
• RFC768 UDP
• RFC791 IP
• RFC792 ICMP
• RFC793 TCP
• RFC826 ARP
• RFC1213 MIB II
• RFC1493 Bridage MIB
• RFC1907 SNMPv2 MIB
• RFC2668 802.3 MAU MIB
• RFC4133 Entity MIB
• RFC4363 IEEE 802.1p MIB
• ZoneDefense MIB
• Private MIB
PoE
PoE standard
• IEEE 802.3af
• IEEE 802.3at
Ports with PoE support
• Ports 1-8
PoE Power Budget
• Up to 240W (when the 180W PWR180AC power adapter is connected, the PoE budget is 140W, and if you connect a more powerful power source such as 300W, the PoE budget can reach 240W, max 30W per PoE)
Physical parameters
Dimensions (L x W x H)
• 210 x 171.2 x 48 mm
The weight
• 2.5 kg
terms of Use
Food
• 46-54 V DC (with the ability to connect up to two power supplies (not included in the scope of delivery))
• Power adapter (not included):
 - Input: 100-240 V AC, 2.5 A, 50/60 Hz
 - Output: 54 V, 3.34 A
Noise level
• 0 dB
Protection against static electricity
• Support of static electricity protection on copper ports (IEC61000-4-5 standard)
Ventilation system
• Passive
Temperature
• Operating: -40 to 65 ° C
• Storage: -40 to 85 ° C
Humidity
• Operating: 0% to 95% non-condensing
• When stored: 0% to 95% non-condensing
Contents of delivery
• Switch DIS-200G-12PS
• Console cable with RJ-45 connector
• Wall mounting kit
• DIN rail mounting kit
• Quick Installation Guide
• CD
Other
EMI
• CE
• FCC
• BSMI
• C-Tick
Security
• UL
Ürünler | Destek  | Haberler  | Hakkında |
