Hızlı Arama
Ürün Özellikleri:
8 port EasySmart 10BASE-T/100BASE-TX/1000BASE-T kompakt anahtar
Genel Özellikler:
Fiziksel Özellikler
Size
Table size
Number of ports
8-port 10/100/1000BaseT
Function on the ports
• IEEE 802.3
• IEEE 802.3u
• Supports full / half duplex (for half-duplex 10/100 Mbit / s, full duplex 1000 Mbit / s)
• Auto-negotiation
• Auto detection of MDI / MDIX
• IEEE 802.3x flow control in full duplex mode
• IEEE 802.3az
Performance
• Bandwidth switch 16 Gbit / c
• Maximum speed packet forwarding: 11.9 Mpps
• MAC-Address Table: 8K entries per device
• Packet Buffer: 2 Mbps
• Flash-Memory: 2 MB
Indicators
• Power (per device)
• Link / Activity / Speed ​​(per port)
Software Functions
VLAN
• Port-based
• 802.1Q tagged VLAN
• Surveillance VLAN
• Management VLAN
• Group VLAN
  - Max. 32 static VLAN
  - Max. 4094 VIDs
Layer 2 features
• MAC Address Table: 8K
• Flow Control
  - 802.3x Flow Control
  - HOL Blocking Prevention
• Jumbo-frames up to 9216 bytes
• IGMP Snooping
  - IGMP v1/v2 Snooping
  - Supports up to 32 IGMP-groups
• Link Aggregation: Group 1, 2-4 ports per group
• The Loopback Detection
• Diagnostic cable
• Port Mirroring
  - One-to-One
• Statistics
  - Tx Ok
  - Tx Error
  - Rx Ok
  - Rx Error
Quality of service (QoS)
• 802.1p
• 4 queues per port
• Mechanisms queuing
  - Strict
  - Weighted Round Robin (WRR)
• Bandwidth Management
  - Port-based (Ingress / Egress, selected from a list with a minimum of 8 kbit / s)
Security
• Static MAC-address: up to 32 entries
• Protection from the broadcast / multicast / unicast storm
Management
• Web-interface GUI (Supports IPv4)
• The SmartConsole
Technology D-Link Green
• Lower power consumption, depending on:
  - Connection status
  - Cable lengths
• RoHS 6
List of RFC standards
• RFC 768 UDP
• RFC 791 IP
• RFC 792 ICMP
• RFC 793 TCP
• RFC 826 ARP
• RFC 951 BootP-client
• RFC 1542 BootP / DHCP client
• RFC 1945 HTTP/1.0
• RFC 2647 802.1p
Fiziksel Özellikler
Power consumption
• Mode Standby: 1,23 W
• Maximum: 4,89 W
Power Input
External universal power supply 100 to 240 VAC, 50/60 Hz
MTBF (hours)
503.585 h
Noise level
0 dB
Heat release
16,68 BTU / hour
Weight
0.42 kg
Measurements
171 x 98 x 28 mm
Fans
no
Operating temperature
From 0 to 50 ° C.
Storage temperature
-10 To 70 ° C
Operating Humidity
From 10 to 95% (non-condensing)
Electromagnetic compatibility
FCC Class A, CE Class A, VCCI Class A, ICES-003, C-Tick
Security
cUL, CE LVD
Ürünler | Destek  | Haberler  | Hakkında |
