Hızlı Arama
Ürün Özellikleri:
5 port 10/100/1000 Base-T ve güç tasarrufu fonksiyonlu Yönetilemeyen Layer 2 Gigabit Anahtar
Genel Özellikler:
Fiziksel Özellikler
Common
• Built-in D-Link Green
• Inexpensive Gigabit solution for home networks and SOHO
• 5 x 10/100/1000 Mbit / s Gigabit
• Switching Matrix: 10 Gbit / s
• Auto MDI / MDIX on all ports
• Switching Method: Store-and-forward
• Ethernet / Fast Ethernet: Full duplex / half duplex
• IEEE 802.3x Flow Control
• Jumbo-frames 9216 bytes
• Supports IEEE 802.1p QoS (4 queues, Strict Mode)
• Supports Cable Diagnostics
• Compliance with the RoHS Directive
• The Plug-and-play
• passive cooling system
Standards
• IEEE 802.3ab 1000BASE-TX Gigabit Ethernet (twisted-pair copper)
• ANSI / IEEE 802.3 NWay speed detection and mode of operation
• Flow control IEEE 802.3h
• IEEE 802.1p QoS
Protocol
CSMA / CD
Data transfer rate
• Ethernet:
  • 10 Mbit / s (half duplex)
  • 20 Mbit / s (full duplex)
• Fast Ethernet:
  • 100 Mbit / s (half duplex)
  • 200 Mbit / s (full duplex)
• Gigabit Ethernet:
  • 2000 Mbit / s (full duplex)
Topology
Star
Network Cables
• 10BASE-T:
  • UTP Cat. 3/4/5/5e (100m max.)
  • EIA/TIA-586 100-ohm STP (100m max.)
• 100BASE-TX, 1000BASE-T:
  • UTP Cat. 5/5e (100m max.)
Interfaces transmission medium
Automatic detection of MDI / MDIX on all ports
Indicators
• Per Port: Link / Activity / Speed
• On the device: Power
Switching Method
Store-and-Forward
MAC-address table
2K entries per device
Study MAC-address
Automatic Update
Speed ​​Packet Filtering / Forwarding
• Ethernet: 14,880 packets per second. the port
• Fast Ethernet: 148,800 packets per second. the port
• Gigabit Ethernet: 1488000 package sec. the port
Packet Buffer
128 Kbyte device
Physical parameters
Power Input
5V/1A DC external power adapter
Power consumption
• Power on. (Standby):
  • Power Input: 0.45 W DC 1.4 W AC
• Max.:
  • Power Input: 2.37 W DC 3.9 W AC
Heat release
• Power on. (Standby): 2,728 BTU / h
• Max.: 13,30 BTU / h
MTBF
1261786 hours
Temperature
• Operating: 0 ° to 50 ° C
• Storage: -10 ° to 70 ° C
Humidity
• Operating: 10% to 90%
• Storage: 5% to 90%
Certificates
• FCC Class B
• ICES-003 Class B
• CE Class B
• C-Tick Class B
• VCCI Class B
• cUL
• LVD
• CB
Ürünler | Destek  | Haberler  | Hakkında |
