DES-1050G/C1EOL EOS
48-port 10/100Base-TX + 2 combo port 10/100/1000BASE-T/SFP Yönetilmeyen Anahtar
Tanımlama
Unmanaged Switch DES-1050G high-density port 10/100Mbps Ethernet is ideal for a cost-effective connection of the working groups. Equipped with a 48-port 10/100 Mbit / s Ethernet, 2 combo ports 10/100/1000BASE-T/SFP and configured in a flat metal housing for mounting in a standard rack, this switch provides an inexpensive connection of up to 48 workstations and 2 Gigabit connections over twisted pair or fiber optic cable.
48 Connects Plug-and-Play to the workplace
All 48 ports 10/100Base-TX Switch DES-1050G are plug-and-play support and auto-detection and polarity of MDI / MDIX.Therefore, DES-1050G provides a simple and inexpensive solution to connect up to 48 computers.
2 Gigabit combo ports
Switch is equipped with 2 combo ports to connect to servers over twisted pair or core switches using fiber optic cable. Using existing Category 5 twisted pair as a transmission medium can immediately connect servers to ports Gigabit Ethernet, without requiring you to install new fiber optic cable. These ports support auto-negotiation 10/100/1000 Mbit / s and auto-negotiation.With the help of these ports can also be connected to multiple switches, together with a view to increasing the number of ports destined for network connections.
Flow control for secure information transfer
The switch supports flow control 802.3h that reduces the number of discarded packets. This is achieved by sending signals collision when the buffer of the receiving port. Thanks to the support of this function, the organization secure connections to servers at speeds 2000Mbps / s in full duplex mode for simultaneous access by multiple workstations without the risk of data loss.
Genel Özellikler
Çözümler
Sipariş Bilgisi
Görseller
DES-1050G/C1/C
Front view
İndir
Destek Merkezi
