Hızlı Arama
Ürün Özellikleri:
Bidirectional Transceiver SFP-1-port 10GBASE-LR (without DDM) for single mode fiber optic cable, power supply 3.3 V (up to 20 km), WDM (TX: 1330nm, RX: 1270nm)
Genel Özellikler:
Fiziksel Özellikler
Compliance with standards
IEEE-802.3ae, 10GBASE-LR
Type form factor
SFP +
Support for fiber optic cable
Single-mode
Transmission distance
20 km
Capabilities
• Hot Plug
• Compatible with MSA
• Compliant with RoHS
Speed
10 Gbit / s
Jack
Simplex LC connector
Uni-/bidirectional
Bidirectional WDM
Wavelength
TX: 1330 nm, RX: 1270 nm
Output power (TX)
• Max.: 0.5 dBm
• Min.: -5.2 DBm
Optical input (RX)
• Max.: 0.5 dBm
• Min.: -12.5 DBm
Sensitivity
-12.5 DBm
Type of cable
Single-mode optical 9/125 micron
Fiziksel Özellikler
Nutrition
3.3
Max. input current
3.3 V: 300 mA
Min. power budget
7.3 dB
Max. power budget
13 dB
Heat release
3.6 kJ / h
MTBF (Hours)
1,920,000
DDM (Digital Diagnostics)
No
Operating temperature
-40 To 85C
Storage temperature
-40 To 85C
Operating Humidity
5% ~ 85%
Humidity
5% ~ 95%
Dimensions (W x D x H)
• Compatible with SFF8432
• 14,8 x 56.5 x 11.85 mm
Weight
22 g
Color Lock
Blue
EMI
CE, FCC, VCCI
Safety
UL, TUV, CDRH
Ürünler | Destek  | Haberler  | Hakkında |
