DSA-5100EOL EOS
4-Port AirSpot Gateway
Description
Double Internet Bandwidth
The DSA-5100 provides 2 WAN ports to double the Internet connection bandwidth. The WAN ports supports 802.3ad Link Aggregation industry standard and can be bonded together into a load-sharing port trunk to eliminate bottlenecks in heavy Internet access environments. The DSA-5100 provides bandwidth management tools for you to assign rational bandwidth usage of the 2 WAN ports.
Total Wireless Management Solution
The DSA-5100 Network Access Control System (NACS) provides functions beyond the AAA standard. Its 4A management solution supports not only Authentication, Authorization and Accounting (AAA), but also Administration for all wireless (and wired) network users. The gateway has a built-in database of up to 60 customized access management rules and up to 2,000 user accounts. The DSA-5100 can support up to 400 users on-line at any single moment. The gateway also supports POP3, RADIUS, and LDAP external authentication for larger-scale hot spot networks. Other features IP plug and play, user bandwidth control, network policy enforcement, customizable user timer, login/logout web-page, online traffic monitoring, and URL redirection provide a number of different ways for your
organization to configure and manage your hot spot as either as a free or revenue-generating service.
Comprehensive Network Protection
The DSA-5100 includes a built-in DHCP server and a built-in high-speed routing engine, an easy-to-use web-based graphical user interface (GUI) with SSL protection to securely and quickly configure the device. Configuration is also capable through the device's RS-232 console port. To prevent unwanted Internet intruders from accessing your network, the DSA-5100 has a built-in Security Firewall with Denial of Service (DoS) prevention. With IP PnP (Plug and Play) and IP/port redirection provided by the DSA-5100, users connecting to the hot spot don't need to re-configure their computer's settings to send or retrieve e-mail or access the Internet.
Ideal Hot Spot Solution
Capable of serving hundreds of simultaneous, discrete users, the DSA-5100 gateway is the perfect system for a mid-size enterprise and organization to provide a wireless hot spot. In a matter of just a few minutes, your business or organization can provide a wired or wireless hot spot while still maintaining a private network that the public will never see. Whether you're an enterprise, merchants association, factory, hospital, school, or public library , the DSA-5100 is your instant hot spot solution.
General features
Certificates
Order info
Pictures
DSA-5100
Front view
Downloads
Support Resources
