Quick find
Product features:
Antenna Extension Cable with RP-N Plug and N Plug Connectors, 1m
General features:
Frequency range
• 2.4~6GHz
VSWR
• 1.7:1 max. at 2.4GHz
• 2.7:1 max. at 5GHz
The insertion loss
• 0.8dB max. at 2.4GHz
• 2dB max. at 5.15~5.85GHz
Resistance
• 50 Ohms
Type of cable
• CFD-200
Cable Length
• 1m
Jack
• RP-N Plug, N Plug
Antenna structure
• Collinear
Temperature
• -40 to 70°C
Humidity
• 95% at 55°C
Dust and moisture protection standard
• IP67
Weight
• 199g
Dimensions
• 1030 x 20.9 x 20.9mm
Products | Support  | News  | About |
