Description
Full-featured wireless SURVEILLANCE camera
D-Link DCS-5230 is a pan and tilt wireless network camera, ideal for small-to-medium business applications and remote monitoring over the Internet. The DCS-5230 is equipped with a 1.3 megapixel CMOS image sensor, built-in IR LED for low-light capture, micro SD card slot for front-end storage and a WPS button for home users to set up a wireless connection within minutes. It also features a built-in infrared LED for night surveillance. DCS-5230 introduces a 1.3 megapixel image sensor that is capable of 10 frames per second at full 1280 x 1024 pixel resolution, and 30 frames per second in 640 x 480 pixels VGA mode. Megapixel resolution provides stunning detail and clarity that is not seen in traditional analog and VGA cameras. In addition they provide large images, and greater power supply and consumption savings in comparison with the CCD sensor.
SHARP IMAGE MONITORING FROM DIFFERENT ANGLES
With sharp, responsive pan/tilt movement and digital zoom, DCS-5230 can monitor from different angles and quickly orientates to focus on any detail. In addition, this camera is designed as a standalone system with a CPU, web server, 16x digital zoom, and advanced video/audio surveillance remote monitoring utility. DCS-5230 provides high quality real-time videos in MPEG-4 and JPEG compression with QVGA/VGA/XGA/SXGA resolution for smoother performance.
VIEW LIVE VIDEO FROM A 3G MOBILE
A live feed from the camera can be accessed on a 3G mobile network by using a compatible mobile phone or PDA with a 3G video player. Users have a flexible and convenient way to remotely monitor a home or office in real time from anywhere within their 3GP service area.
INTELLIGENT & EASY TO USE
To save disk space and time, images can be recorded to a hard drive only when motions are detected. This eliminates the need for round-the-clock non-stop surveillance. Images can be recorded manually or by a pre-set schedule. Playback consumes little time with triggered event browsing and fast database searching. Users can also set up automated e-mail alerts for all the unusual events. D-ViewCam is included for monitoring and managing 32 cameras in a single display from a central location. Furthermore, the camera provides a Privacy Mode option. Users can set a schedule to hide the camera lens. So, when the camera enters into the privacy mode, the lens rotates backwards and hides to protect the privacy of the owner. The camera adheres to the Universal Plug-n-Play specification, which allows computers running on Windows XP/Vista to automatically recognize the camera and add it to the network. Users can sign up with one of the many free Dynamic DNS services available on the web and assign an easy-to-remember name and domain to the camera (e.g. ww.mycamera.myddns.com).This allows them to remotely access the camera without having to remember the IP address.
General features
CAMERA SPECIFICATIONS
• 1.3 Mega pixel 1/3” CMOS sensor
• Standard fixed mount type lens, 3.98 mm lens, F2.0
• AGC/AWB/AES
• Electronic shutter: 1/60 to 1/15000 sec.
• Standard fixed mount type lens: 4mm, F2.0
• 62˚ field of view
LED INDICATORS
• Link/Power: Green/Red
• WPS: Blue
RESET BUTTON
• Reset to factory default settings
VIDEO FEATURES
• Adjustable image size and quality
• Time stamp and text overlays
• Three configurable motion detection windows
• Flip & mirror
Video Algorithm Suport
• JPEG for still images
• Enhanced video compression using MPEG4 Simple Profile
• MPEG4/MJPEG dual format compression
VIDEO RESOLUTION
• VGA (640 x 480)
• 640 x 480 at 30 fps
• 320 x 240 at 30 fps
• 160 x 120 at 30 fps
• XGA (1024 x 768)
• 1024 x 768 at 10 fps
• 512 x 384 at 10 fps
• 256 x 192 at 10 fps
• SXGA (1280 x 1024)
• 1280 x 1024 at 10 fps
PAN/TILT/Zoom
• Pan Range: 130° ~ -180°
• Tilt Range: +5° ~ - 85°
• Digital Zoom: 16x
Microphone
• Omni-directional
• Frequency 20 to 20,000 Hz
• S/N ratio: over 58 dB
AUDIO
• Sampling Rate:
• GSM-AMR: 12.2 Kbps
• PCM: 8 Kbps
Network connectivity
• Radio and Modulation Schemes
802.11b: DQPSK, DBPSK and CCK
802.11g: BPSK, QPSK, 16QAM, 64QAM, OFDM
• Operating Frequency: 2400 to 24835MHz
• Wireles Data Rates
IEEE 802.11n: Up to 300 Mbps
802.11b: 11, 5.5, 2 and 1 Mbps
802.11g: 54, 48, 36, 24, 18, 12, 9 and 6 Mbps
• Reciever Sensitivity
802.11b:
11 Mbps (CCK): -84 dBm
5.5 Mbps (CCK): -86 dBm
2 Mbps (DQPSK): -88 dBm
1 Mbps (DBPSK): -90 dBm
(typically @PER < 8% packet size 1024 and @25º C + 5º C)
802.11g:
54 Mbps (OFDM): -66 dBm
48 Mbps (OFDM): - 70 dBm
36 Mbps (OFDM): -76 dBm
24 Mbps (OFDM): -79 dBm
18 Mbps (OFDM): -83 dBm
12 Mbps (OFDM): -85 dBm
9 Mbps (OFDM): -86 dBm
6 Mbps (OFDM): -86 dBm
(typically @PER <10% packet size 1024 and @25º C + 5º C)
• Transmitter Output Power
802.11n: 12 dBm (typical)
802.11g: 12 dBm (typical)
802.11b: 16 dBm (typical)
• Antennas
2 dBi Gain dipole antenna with reverse SMA plug
Operating Frequency: 2.4 Ghz
NETWORK INTERFACE
• IEEE 802.11n
• 10/100BASE-TX Fast Ethernet with auto-MDI/MDIX support
• NETWORK PROTOCOL SUPPORT
• IPv4, ARP, TCP, UDP, ICMP, DHCP Client, NTP Client (D-Link), DNS Client, DDNS Client (D-Link), SMTP Client, FTP Client, HTTP Server, Samba Client, PPPoE, RTP, RTSP, RTCP, 3GPP
REMOTE MANAGEMENT
• Configuration accessible via web browser
• Take snapshots/video clips and save to local hard drive via web browser
SECURITY
• Administrator and user group protected
• Password authentication
• Wireless LAN security: 64/128-bit WEP, WPA-PSK and WPA2 data encryption
SurveilLance
(Motion detection weekly schedule)
• Upload snapshots/video clips via email
• Upload snapshots/video clips via FTP
SYSTEM REQUIREMENTS
• Operating System: Microsoft Windows Vista/XP/7/ Linux/ MAC OS X10.3 or above
• Browser: Internet Explorer v6.0 or above
Suported PDA, Mobile Phones & Software
• Handsets with 3GPP player
• Packet Video Player 3.0
• QuickTime 6.5
• Real Player 10.5
• Windows 2000, XP, Vista
