Quick find
Product features:
Wireless 802.11n nano USB adapter, compact size
EOL EOS
General features:
STANDARDS
• IEEE 802.11n (draft 2.0)
• IEEE 802.11b
• IEEE 802.11g
INTERFACE
USB 2.0
FREQUENCY RANGE
2.4GHz to 2.4835GHz
ANTENNA
PIFA antenna
SECURITY
• WEP
• WiFi Protection Access (WPA & WPA2)
• WiFi Protection Setup
• PBC/PIN
LED
Link/Activity
CERTIFICATIONS
• FCC Class B
• IC
• Wi-Fi
• CE
• C-Tick
• Windows Vista certified
OPERATING TEMPERATURE
0˚ to 40˚C (32˚ to 104˚F)
OPERATING HUMIDITY
10 ~ 90% (Non-condensing)
DIMENSIONS
18(W) x 34.4(D) x 7.7(H) mm (0.7 x 1.4 x 0.3 inches)
WEIGHT
3.1g (0.007lbs)
OS SUPPORT
Windows 2000, XP, Vista (32/64 bit)
1 Maximum wireless signal rate derived from IEEE Standard 802.11g and draft 802.11n specifications. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual data throughput rate. Environmental factors will adversely affect wireless signal range. Wireless range and speed rates are D-Link relative performance measurements based on the wireless range and speed rates of D-Link products.
This product is based on IEEE draft 2.0 802.11n specifications and is not guaranteed to be forward compatible with future versions of IEEE 802.11n specifications. Compatibility with draft 802.11n devices from other manufacturers that are not Wi-Fi® certified is not guaranteed. All references to speed and range are for comparison purposes only. Product specifications, size, and shape are subject to change without notice, and actual product appearance may differ from that depicted herein.
Products | Support  | News  | About |
