Quick find
Product features:
5-Port 10/100/1000M Unmanaged Switch
The DGS-1005D 5-Port 10/100/1000M Unmanaged Switch is part of D-Link™s new series of SOHO devices that make use of D-Link™s Green Technology, providing energy savings, reduced heat, and a longer product life without sacrificing performance or functionality. It provides five Gigabit ports for easy expansion of your network and a quick way to upgrade your network to Gigabit connectivity. An energy-efficient power adapter (Energy Star Level VI qualified),
minimized use of harmful substances (RoHS compliant), and recyclable packaging make this switch truly environmentally friendly.
Fast and Smooth Networking
With data transfer speeds of up to 2000 Mbps on Gigabit Ethernet, the D-Link DGS-1005D 5-Port 10/100/1000M Unmanaged Switch is ideal all types of networking tasks. Support for 802.3x Flow Control means smoother network traffic, resulting in an overall boost in performance and reliability. Featuring QoS, the DGS-1005D prioritizes network traffic by type so that time-sensitive data is delivered efficiently, even during bursts of high data traffic. This helps ensure an optimal experience for streaming media, VoIP calls, and online gaming.
Conserve Energy
The 5-Port 10/100/1000M Unmanaged Switch helps you conserve energy automatically through several methods. It automatically powers down ports that have no link, allowing the switch to save a substantial amount of power by cutting power usage for unused ports or ports connected to computers that have been shut down.
The 5-Port 10/100/1000M Unmanaged Switch was designed with the environment in mind, and is compliant with Energy Star Level VI, as well as with the stringent CEC and MEPS regulations that require the use of energy efficient power adapters. The switch is also built to follow RoHS standards to minimize use of hazardous materials, and uses recyclable packaging that helps reduce waste, complying with the WEEE directive.
Products | Support  | News  | About |
