Quick find
Product features:
xStack L2+ Managed Stackable Gigabit Switch with 20 ports SFP, 4 combo 10/100/1000Base-T/SFP ports and 2 ports SFP+
Project
General features:
General
• Interfaces
• 20 SFP ports
• 4 Combo 10/100/1000BASE-T/SFP ports
• 2 SFP+ ports
• Optional Redundant Power Supply: DPS-500
• Console Port: RJ-45
• Management Port: 10/100BASE-T
• Alarm Port: 1
• SD Card Slot: 1
Performance
• Switch Fabric: 88Gbps
• Packet Forwarding Rate: 65.47Mpps
• Packet Buffer Memory: 2MB
• MAC Address Table: 16K Entries
• IP v4/v6 Routing Table: 1K/512 Entries
• IP v4/v6 L3 Forwarding Table: 2K/1K Entries
• Jumbo Frame Size: 13000 bytes
PoE
PoE Standards:
• 802.3af and 802.3at
PoE Power Budget:
• 370 watts
• 760 watts (with DPS-700 RPS)
Software Features
Standard Image (SI) Features
Stackability
• Physical Stacking
• Up to 40G Stacking Bandwidth
• Up to 6 units per Stack
• Virtual Stacking:
• D-Link Single IP Management (SIM)
• Up to 32 units per Virtual Stack
L2 Features
• MAC Address Table: 16K entries
• Flow Control
• 802.3x Flow Control
• HOL Blocking Prevention
• Jumbo Frames up to 13 Kbytes
• 802.3ad Link Aggregation
• Max. 32 groups per device, 8 Gigabit ports per group
• Spanning Tree Protocols
• 802.1D STP
• 802.1w RSTP
• 802.1s MSTP
• BDPU Filtering
• Root Restriction
• Loopback Detection
• Port Mirroring
• One-to-One
• Many-to-One
• Flow-based
• RSPAN Mirroring
L2 Multicasting
• IGMP Snooping
• IGMP v1/v2/v3 Snooping
• Supports 1024 IGMP groups
• Port/Host-based IGMP Snooping Fast Leave
• Limited IP Multicast
• Up to 24 IGMP filtering profiles, 32 ranges per profile
• MLD Snooping
• MLD v1/v2 Snooping
• Support 1024 MLD Groups
• Host-based MLD Snooping Fast Leave
VLAN
• VLAN Group
• Max.4K VLAN Groups
• GVRP
• Max. 255 Dynamic VLAN Groups
• 802.1Q Tagged VLAN
• Port-based VLAN
• 802.1v Protocol VLAN
• Voice VLAN
• MAC-based VLAN
• ISM VLAN
• Assymetric VLAN
• Private VLAN
• VLAN Trunking
QoS (Quality of Service)
• 802.1p
• 8 queues per port
• Queue Handling
• Strict Priority
• Weighted Round Robin (WRR)
• Strict + WRR
• Supports following actions for flows
• Remark 802.1p Priority Tag
• Remark TOS/DSCP Tag
• Bandwidth Control
• CoS based on
• Switch Port
• VLAN ID
• 802.1p Priority Queues
• MAC Address
• IPv4 Address
• DSCP
• Protocol Type
• TCP/UDP Port
• User-Defined Packet Content
• IPv6 Address
• IPv6 Traffic Class
• IPv6 Flow Label
• Bandwidth Control
• Port-based (Ingress/Egress, Min. Granularity 8Kbps)
• Flow-based (Ingress/Egress, Min. Granularity 8Kbps)
• Three Color Marker
• CIR/PIR minimum granularity: 8kbps
• Two Rate Three Color Marker (trTCM), CBS/PBS
• Single Rate Three Color Marker (srTCM), CBS/EBS
Access Control List (ACL)
• ACL based on
• 802.1p Priority
• VLAN ID
• MAC Address
• Ether Type
• IPv4 Address
• DSCP
• Protocol Type
• TCP/UDP Port Number
• IPv6 Address
• IPv6 Flow Label
• Supports up to 1.5K Ingress access rules
• Time-based ACL
• CPU Interface Filtering
Security
• SSH v2
• SSL v1/v2/v3
• Port Security
• Up to 64 MAC addresses per port/VLAN
• Broadcast/Multicast/Unicast Storm Control
• Traffic Segmentation
• D-Link Safeguard Engine
• NetBIOS/NetBEUI Filtering
• DHCP Server Screening
• ARP Spoofing Prevention
• DoS Attack Prevention
• BPDU Attack Protection
AAA
• 802.1X
• Port-based Access Control
• Host-based Access Control
• Identity-driven Policy (VLAN, ACL or QoS) Assignment
• Authentication Database Failover
• Web-based Access Control (WAC):
• MAC-based Access Control (MAC):
• Japan Web-based Access Control (Host-based JWAC)
• Guest VLAN
• Microsoft® NAP
• Support 802.1X NAP
• Support DHCP NAP
• RADIUS Accounting
• TACACS+ Accounting
• RADIUS and TACACS authentication for switch access
• Four levels of User Account control
Green Features
• Compliant with RoHS
• Power Saving by Link Status
• Power Saving by Cable Length
• IEEE 802.3az Energy Efficient Ethernet (EEE)
Operation, Administration & Management (OAM)
• Cable Diagnostics
Management
• Web-based GUI
• Command Line Interface (CLI)
• Telnet Server
• Telnet Client
• TFTP Client
• ZModem
• SNMP v1/v2c/v3
• SNMP Traps
• System Log
• RMON v1:
• Supports 1,2,3,9 groups
• RMON v2:
• Supports ProbeConfig group
• LLDP
• BootP/DHCP Client
• DHCP Auto-Configuration
• DHCP Relay
• DHCP Relay Option 12
• DHCP Relay Option 82
• Flash File System
• Multiple Images
• Multiple Configurations
• CPU Monitoring
• Debug Command
• SNTP
• Password Recovery
• Password Encryption
• Trusted Host
• Microsoft® NLB (Network Load Balancing) Support
• ICMPv6
MIB
• RFC 1213 MIB II
• RFC 4188 Bridge MIB
• RFC 1157, 2571-2576 SNMP MIB
• RFC 1907 SNMPv2 MIB
• RFC 1757, 2819 RMON MIB
• RFC 2021 RMONv2 MIB
• RFC 1398, 1643, 1650, 2358, 2665 Ether-like MIB
• RFC 2674 802.1p MIB
• RFC 2233, 2863 IF MIB
• RFC 2925 Ping & Traceroute MIB
• RFC 2674, 4363 802.1p MIB
• RFC1065, 1066, 1155, 1156, 2578 MIB Structure
• RFC1157, 2571-2576 SNMP MIB
• RFC4022 MIB for TCP
• RFC4113 MIB for UDP
• RFC4293 IPv6 SNMP Mgmt Interface MIB
RFC Standard Compliance
• RFC 768 UDP
• RFC 791 IP
• RFC 792, 2463, 4443 ICMP
• RFC 793 TCP
• RFC 826 ARP
• RFC 3513, 4291, IPv6 Addressing Architecture
• RFC 2893, 4213 IPv4/IPv6 dual stack function
• RFC 2463, 4443 ICMPv6
• RFC 2462, 4862 IPv6 Stateless Address Auto
• RFC 2462, 4862 IPv6 Stateless Address Auto Configuration
• RFC 2464 IPv6 Ethernet and definition
• RFC 1981 Path MTU Discovery for IPv6
• RFC 2460 IPv6
• RFC 2461, 4861 Neighbor Discovery for IPv6
• RFC 783 TFTP
• RFC 2068 HTTP
• RFC 1492 TACACS
• RFC 2866 RADIUS Accounting
• RFC 2474, 3260 DiffServ
• RFC 1321, 2284, 2865, 3580, 3748 Extensible
• Authentication Protocol (EAP)
• RFC 2571, 2572, 2573, 2574, SNMP
• IPv6 Ready Logo Phase 2
• RFC 854 Telnet
• RFC 951, 1542 BootP
Enhanced Image (EI) Features
L2 Features
• Ethernet Ring Protection Switching (ERSP)
VLAN
• Double VLAN (Q-in-Q)
• Port-based Q-in-Q
L3 Features
• Max. 16 IP Interfaces
• ARP Proxy
• IPv6 Neighbour Discovery (ND)
L3 Routing
• Static Route
• 512 static routing entries for IPv4/IPv6
• Supports up to 512 egress access rules
Security
• IP-MAC-Port Binding
• ARP Packet Inspection
• IP Packet Inspection
• DHCP Snooping
• IPv6 ND Snooping
• Support up to 510 Address Binding Entries per Device
AAA
• Compound Authentication
• 802.3ah Ethernet Link OAM
• 802.3ah D-Link Extension: D-link Unidirectional Link Detection (DULD)
• ITU-T Y.1731
Management
• sFlow
• PPPoE Circuit-ID Tag Insertion
MTBF (hours)
301667
Acoustics
below 30°C: < 38.7dB
above 30°C~: < 46.2dB
Heat dissipation
187.6 BTU/hr
Power Input
100 to 240VAC, 50/60Hz
Max Power Consumption
55 watts
Dimensions
441 x 310 x 44mm
Weight
4.04kg
Ventilation
Smart Fan1 (> 39°C: High Speed; < 36°C: Low Speed)
Operating temperature
0° to 50°C
Storage temperature
-40° to 70°C
Operating humidity
10% to 90% non-condensing
Storage humidity
5% to 90% non-condensing
Emission (EMI)
FCC Class A, CE Class A, VCCI Class A, IC, C-Tick
Safety
CB, cUL, LVD
Certification
Products | Support  | News  | About |
