DIR-882EOL EOS
AC2600 MU-MIMO Wi-Fi Gigabit Router with 3G/LTE Support and 2 USB Ports
Apraksts
USB Ports
The router is equipped with two USB ports for connecting a USB modem, a USB storage device or a printer. You are able to quickly connect to the Internet via a USB modem and use a USB storage device as a network drive.
Wireless Interface
Using the DIR-882 device, you are able to quickly create a high-speed wireless network at home or in your office, which lets computers and mobile devices access the Internet virtually anywhere (within the operational range of your wireless network). Simultaneous activity of 2.4GHz band and 5GHz band allows performing a wide range of tasks. The router can operate as a base station for connecting wireless devices of the standards 802.11a, 802.11b, 802.11g, 802.11n, and 802.11ac (at the wireless connection rate up to 2600Mbps )1.
Secure Wireless Connection
The router supports multiple functions for the wireless interface: several security standards (WEP, WPA/WPA2), MAC address filtering, WPS, WMM.
In addition, the device is equipped with a button for switching the Wi-Fi network off/on. If needed, for example, when you leave home, you can easily switch the router’s WLAN by pressing the button, and devices connected to the LAN ports of the router will stay online.
Multi-user MIMO technology allows to distribute the router's resources to let multiple wireless clients use the Wi-Fi network efficiently, keeping high rates for HD media streaming, lag-free gaming, and fast transfer of large files.
Transmit Beamforming technology allows to flexibly change the antennas' radiation pattern and to redistribute the signal directly to wireless devices connected to the router.
Smart adjustment of Wi-Fi clients is useful for networks based on several D-Link access points or routers – when the smart adjustment function is configured on each of them, a client always connects to the access point (router) with the highest signal level.
Support of guest Wi-Fi network allows you to create a separate wireless network with individual security settings. Devices connected to the guest network will be able to access the Internet, but will be isolated from the devices and resources of the router's LAN.
Security
The wireless router DIR-882 includes a built-in firewall. The advanced security functions minimize threats of hacker attacks, prevent unwanted intrusions to your network, and block access to unwanted websites for users of your LAN.
In addition, the router supports IPsec and allows to create secure VPN tunnels.
Built-in Yandex.DNS service protects against malicious and fraudulent web sites and helps to block access to adult content on children's devices.
Easy configuration and update
You can configure the settings of the wireless router DIR-882 via the user-friendly web-based interface (the interface is available in two languages – in Russian and in English).
The configuration wizard allows you to quickly switch DIR-882 to one of the following modes: router (for connection to a wired or wireless ISP), access point, repeater, or client, and then configure all needed setting for operation in the selected mode in several simple steps.
Also DIR-882 supports configuration and management via D-Link Click'n'Connect mobile application for Android smartphones.
You can simply update the firmware: the router itself finds approved firmware on D-Link update server and notifies when ready to install it.
1Up to 800Mbps for 2.4GHz and up to 1732Mbps for 5GHz.
Īpašības
Hardware
Processor
• MT7621A (880MHz, dual core)
RAM
• 128MB, DDR3
Flash
• 16MB, SPI
Interfaces
• 10/100/1000BASE-T WAN port
• 4 10/100/1000BASE-T LAN ports
• USB 3.0 port
• USB 2.0 port
LEDs
• POWER
• INTERNET
• WLAN 2.4G
• WLAN 5G
• USB 3.0
• USB 2.0
Buttons
• POWER button to power on/power off
• WiFi button to enable/disable wireless network
• WPS button to set up wireless connection
• RESET button to restore factory default settings
Antenna
• Four external non-detachable antennas 5dBi gain
MIMO
• 4 x 4
Power connector
• Power input connector (DC)
Software
WAN connection types
• LTE
• 3G
• PPPoE
• IPv6 PPPoE
• PPPoE Dual Stack
• Static IPv4 / Dynamic IPv4
• Static IPv6 / Dynamic IPv6
• PPPoE + Static IP (PPPoE Dual Access)
• PPPoE + Dynamic IP (PPPoE Dual Access)
• PPTP/L2TP + Static IP
• PPTP/L2TP + Dynamic IP
Network functions
• Support of IEEE 802.1X for Internet connection
• DHCP server/relay
• Stateful/Stateless mode for IPv6 address assignment, IPv6 prefix delegation
• Automatic obtainment of LAN IP address (for access point/repeater/client modes)
• DNS relay
• Dynamic DNS
• Static IP routing
• Static IPv6 routing
• IGMP Proxy
• RIP
• Support of UPnP IGD
• Support of VLAN
• WAN ping respond
• Support of SIP ALG
• Support of RTSP
• WAN reservation
• Built-in UDPXY application
• XUPNPD plug-in
Firewall functions
• IP filter
• IPv6 filter
• MAC filter
• URL filter
• DMZ
• Prevention of ARP and DDoS attacks
• Virtual servers
• Built-in Yandex.DNS web content filtering service
• Built-in SafeDNS web content filtering service
VPN
• IPsec tunnels
USB interface functions
• USB modem
- Auto connection to available type of supported network (4G/3G/2G)
- Auto configuration of connection upon plugging in USB modem
- Enabling/disabling PIN code check, changing PIN code1
• USB storage
- File browser
- Print server
- Access to storage via accounts
- Built-in Samba/FTP/DLNA server
- Built-in Transmission torrent client; uploading/downloading files from/to USB storage
Management
• Local and remote access to settings through TELNET/WEB (HTTP/HTTPS)
• Bilingual web-based interface for configuration and management (Russian/English)
• Support of Click'n'Connect application for Android smartphones
• Support of logging to remote host/connected USB storage
• Ping utility
• Traceroute utility
• TR-069 client
Wireless Module Parameters
Standards
• IEEE 802.11a/n/ac
• IEEE 802.11b/g/n
Frequency range
• 2400 ~ 2483.5MHz
• 5150 ~ 5350MHz
• 5650 ~ 5725MHz
Wireless connection security
• WEP
• МАС filter
• WPS (PBC/PIN)
Advanced functions
• Support of client mode
• WMM (Wi-Fi QoS)
• Information on connected Wi-Fi clients
• Advanced settings
• Smart adjustment of Wi-Fi clients
• Guest Wi-Fi / support of MBSSID
• Periodic scan of channels, automatic switch to least loaded channel
• Support of 802.11ac (5GHz) and 802.11n (2.4GHz) TX Beamforming
Wireless connection rate2
• IEEE 802.11a: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
• IEEE 802.11b: 1, 2, 5.5, and 11Mbps
• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
• IEEE 802.11n (2.4GHz): 6,5–600Mbps (MCS0–MCS30) to 800Mbps (QAM256)
• IEEE 802.11n (5GHz): from 6,5 to 600Mbps (from MCS0 to MCS30)
• IEEE 802.11ac (5GHz): from 6,5 to 1732Mbps (from MCS0 to MSC9)
Transmitter output power
• 802.11a (typical at room temperature 25 °C)
15dBm at 6, 54Mbps
• 802.11b (typical at room temperature 25 °C)
15dBm at 1, 11Mbps
• 802.11g (typical at room temperature 25 °C)
15dBm at 6, 54Mbps
• 802.11n (typical at room temperature 25 °C)
2.4GHz
15dBm at MCS0, 7
5GHz
15dBm at MCS0, 7
• 802.11ac (typical at room temperature 25 °C)
15dBm at MCS0, 9
Receiver sensitivity
• 802.11a
-96dBm at 6Mbps
-78dBm at 54Mbps
• 802.11b
-96dBm at 1Mbps
-90dBm at 11Mbps
• 802.11g
-95dBm at 6Mbps
-76dBm at 54Mbps
• 802.11n
2.4GHz, HT20
-95dBm at MCS0
-76dBm at MCS7
2.4GHz, HT40
-92dBm at MCS0
-72dBm at MCS7
5GHz, HT20
-95dBm at MCS0
-76dBm at MCS7
5GHz, HT40
-93dBm at MCS0
-73dBm at MCS7
• 802.11ac
VHT20
-96 дБм при MCS0
-73 дБм при MCS8
VHT40
-92 дБм при MCS0
-68 дБм при MCS9
VHT80
-88 дБм при MCS0
-64 дБм при MCS9
Modulation schemes
• 802.11a: BPSK, QPSK, 16QAM, 64QAM with OFDM
• 802.11g: BPSK, QPSK, 16QAM, 64QAM with OFDM
• 802.11n: BPSK, QPSK, 16QAM, 64QAM, 256QAM with OFDM
• 802.11ac: BPSK, QPSK, 16QAM, 64QAM, up to 256QAM with OFDM
Physical Parameters
Dimensions (L x W x H)
• 259 x 184 x 46 mm (10.8 x 7.24 x 1.81 in)
Weight
• 565 g (1.25 lb)
Operating Environment
Power
• Output: 12V DC, 2.5A
Temperature
• Operating: from 0 to 40 °C
• Storage: from -20 to 65 °C
Humidity
• Operating: from 10% to 90% (non-condensing)
• Storage: from 5% to 95% (non-condensing)
Delivery Package
• Router DIR-882
• Power adapter DC 12V/2.5A
• Ethernet cable (CAT 5E)
Supported USB modems3
GSM
• Alcatel X500
• D-Link DWM-152C1
• D-Link DWM-156A6
• D-Link DWM-156A7
• D-Link DWM 156A8
• D-Link DWM-156C1
• D-Link DWM-157B1
• D-Link DWM-157B1 (Velcom)
• D-Link DWM-158D1
• D-Link DWR-710
• Huawei E150
• Huawei E1550
• Huawei E156G
• Huawei E160G
• Huawei E169G
• Huawei E171
• Huawei E173 (Megafon)
• Huawei E220
• Huawei E3131 (MTS 420S)
• Huawei E352 (Megafon)
• Prolink PHS600
• Prolink PHS901
• ZTE MF112
• ZTE MF192
• ZTE MF626
• ZTE MF627
• ZTE MF652
• ZTE MF667
• ZTE MF668
• ZTE MF752
LTE
• Huawei E3131
• Huawei E3272
• Huawei E3351
• Huawei E3372
• Huawei E367
• Huawei E392
• Megafon M100-1
• Megafon M100-2
• Megafon M100-3
• Megafon M100-4
• Megafon M150-1
• Megafon M150-2
• Quanta 1K6E (Beeline 1K6E)
• MTS 824F
• MTS 827F
• Yota LU-150
• Yota WLTUBA-107
• ZTE MF823
• ZTE MF827
Smartphones in USB tethering mode
• Some models of Android smartphones
1For GSM USB modems and some models of LTE USB modems.
2Maximum wireless signal rate is derived from IEEE standard 802.11ac and 802.11n specifications. In order to get the rate of 800Mbps in the 2.4GHz band, a Wi-Fi client should support MIMO 4x4 and QAM256 modulation scheme. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual data throughput rate. Environmental factors will adversely affect wireless signal range.
3The manufacturer does not guarantee proper operation of the router with every modification of the firmware of USB modems.
Sertifikāti
Informācija pasūtījumam
DIR-882  AC2600 MU-MIMO Wi-Fi Gigabit Router with 3G/LTE Support and 2 USB Ports
Attēli
DIR-882A1 / R1
View from the right
View from the right
View from the right
Left side view
Back view
Pārlādēt
Skatiet arī
