Ātrā meklēšana
Produkta iespējas:
Wireless AC1200 Dual-Band Gigabit Cloud Router USB 3.0
Īpašības:
Device Interfaces
• 802.11 a/b/g/n/ac wireless LAN
• Four 10/100/1000 Gigabit LAN ports
• 10/100/1000 Gigabit WAN port
• USB 3.0 port
Antenna Type
• Four internal antennas
Standards
• IEEE 802.11ac (draft)
• IEEE 802.11n
• IEEE 802.11g
• IEEE 802.11b
• IEEE 802.11a
• IEEE 802.3
• IEEE 802.3u
Wireless Speed
• IEEE 802.11a: 6, 9, 12, 18, 24, 36, 48, 54 Mbit/s
• IEEE 802.11b: 1, 2, 5.5, 11 Mbit/s
• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mbit/s
• IEEE 802.11n (2.4 GHz/5 GHz): 6.5 to 300 Mbit/s (MCS0 to MCS15)
• IEEE 802.11ac: from 6.5 to 866 Mbit/s
Output Power of Transmitter
• IEEE 802.11a:
  17 dBm (+/-2dB) at 6, 9 Mbit/s
  17 dBm (+/-2dB) at 12~36 Mbit/s
  16 dBm (+/-2dB) at 48 Mbit/s
  15 dBm (+/-2dB) at 54 Mbit/s
• IEEE 802.11b: 17dBm at 1, 2, 5.5, 11 Mbit/s
• IEEE 802.11g:
  17 dBm at 6, 9 Mbit/s
  17 dBm at 12, 18 Mbit/s
  17 dBm at 24, 36, 48 Mbit/s
  16 dBm at 54 Mbit/s
• IEEE 802.11n (5 GHz):
  HT20
  17dBm (+/-2dB) at MCS0/1 and MCS8~9
  17dBm (+/-2dB) at MCS2~MCS5 and MCS10~MCS13
  16dBm (+/-2dB) at MCS6 and MCS14
  15dBm (+/-2dB) at MCS7 and MCS15
  HT40
• IEEE 802.11n (2.4 GHz)
  HT20
  14dBm at MCS0/1 and MCS8~9
  14dBm at MCS2~MCS5 and MCS10~MCS13
  14dBm at MCS6 and MCS 14
  14dBm at MCS7 and MCS 15
  HT40
  12dBm at MCS0/1 and MCS8~9
  12dBm at MCS2~MCS5 and MCS10~MCS13
  12dBm at MCS6 and MCS14
  12dBm at MCS7 and MCS15
• IEEE 802.11ac (5GHz)
  HT20
  17dBm at MCS0/1 and MCS9~10
  17dBm at MCS2~MCS5 and MCS11~MCS14
  16dBm at MCS6 and MCS15
  15dBm at MCS7 and MCS16
  14dBm at MCS8 and MCS17
  HT40
  17dBm at MCS0/1 and MCS10~11
  17dBm at MCS2~MCS5 and MCS12~MCS15
  16dBm at MCS6 and MCS16
  15dBm at MCS7 and MCS17
  14dBm at MCS8 and MCS18
  13dBm at MCS9 and MCS19
  HT80
  16dBm at MCS6 and MCS 16
  15dBm at MCS7 and MCS 17
  14dBm at MCS8 and MCS 18
  13dBm at MCS9 and MCS 19
Receiver Sensitivity
• IEEE 802.11a:
  -82dBm at 6 Mbit/s
  -81dBm at 9 Mbits/s
  -79dBm at 12 Mbit/s
  -77dBm at 18 Mbit/s
  -74dBm at 24 Mbit/s
  -70dBm at 36 Mbit/s
  -66dBm at 48 Mbit/s
  -65dBm at 54 Mbit/s
• IEEE 802.11b:
  -76 dBm at 2 Mbit/s
  -76 dBm at 11 Mbit/s
• IEEE 802.11g:
  -82 dBm at 6 Mbit/s
  -81 dBm at 9 Mbits/s
  -79 dBm at 12 Mbit/s
  -77 dBm at 18 Mbit/s
  -74 dBm at 24 Mbit/s
  -70 dBm at 36 Mbit/s
  -66 dBm at 48 Mbit/s
  -65 dBm at 54 Mbit/s
  HT20
  -82dBm at (MCS0/8)
  -79dBm at (MCS1/9)
  -77dBm at (MCS2/10)
  -74dBm at (MCS3/11)
  -70dBm at (MCS4/12)
  -66dBm at (MCS5/13)
  -65dBm at (MCS6/14)
  -64dBm at (MCS7/15)
  HT40
  -79dBm at (MCS0/8)
  -76dBm at (MCS1/9)
  -74dBm at (MCS2/10)
  -71dBm at (MCS3/11)
  -67dBm at (MCS4/12)
  -63dBm at (MCS5/13)
  -62dBm at (MCS6/14)
  -61dBm at (MCS7/15)
• IEEE 802.11n (2.4 GHz):
  HT20
  -82dBm at (MCS0/8)
  -79dBm at (MCS1/9)
  -77dBm at (MCS2/10)
  -74dBm at (MCS3/11)
  -70dBm at (MCS4/12)
  -66dBm at (MCS5/13)
  -65dBm at (MCS6/14)
  -64dBm at (MCS7/15)
  HT40
  -79dBm at (MCS0/8)
  -76dBm at (MCS1/9)
  -74dBm at (MCS2/10)
  -71dBm at (MCS3/11)
  -67dBm at (MCS4/12)
  -63dBm at (MCS5/13)
  -62dBm at (MCS6/14)
  -61dBm at (MCS7/15)
• IEEE 802.11ac (5GHz):
  HT20
  -82dBm at (MCS0)
  -79dBm at (MCS1)
  -77dBm at (MCS2)
  -74dBm at (MCS3)
  -70dBm at (MCS4)
  -66dBm at (MCS5)
  -65dBm at (MCS6)
  -64dBm at (MCS7)
  -59dBm at (MCS8)
  -57dBm at (MCS9)
  HT40
  -79dBm at (MCS0)
  -76dBm at (MCS1)
  -74dBm at (MCS2)
  -71dBm at (MCS3)
  -67dBm at (MCS4)
  -63dBm at (MCS5)
  -62dBm at (MCS6)
  -61dBm at (MCS7)
  -56dBm at (MCS8)
  -54dBm at (MCS9)
  HT80
  -76dBm at (MCS0)
  -73dBm at (MCS1)
  -71dBm at (MCS2)
  -68dBm at (MCS3)
  -64dBm at (MCS4)
  -60dBm at (MCS5)
  -59dBm at (MCS6)
  -58dBm at (MCS7)
  -53dBm at (MCS8)
  -51dBm at (MCS9)
Minimum System Requirements
• Windows 7/Vista/XP SP3 or Mac OS X 10.4 or higher
• Microsoft Internet Explorer 6 or higher, Firefox 1.5 or higher, or other Java-enabled browser
• CD-ROM
• Ethernet network interface
• Cable or DSL modem
• Subscription with an Internet Service Provider
Advanced Features
• Guest Zone
• SharePort™ web access
• Multi-language web setup wizard
• Green Ethernet
• DLNA Media server support
• Dual Active Firewall
• VPN passthrough/multi-session PPTP/L2TP/IPSec
mydlink Features
• Remote Management
• View current upload/download bandwidth
• View currently connected clients
• View web browsing history per client
• Block/unblock client network access
• Manage wireless network details
• Accessible through a web browser or iOS or Android mobile app
Mobile App Support
• mydlink Lite
• SharePort Mobile
• QRS Mobile
Wireless Security
• WPA & WPA2 (Wi-Fi Protected Access)
• Wi-Fi Protected Setup (WPS) PIN/PBC
Fiziskie raksturlielumi
Dimensions (L x W x D)
• 119.0 x 99.0 x 191.5 mm
Weight
• 0.35 kg (0.77 lbs)
Power
• Input: 100 to 240V AC, 50/60 Hz
• Output: 12V DC, 2 A
Temperature
• Operating: 0 to 40°C
• Storage: -20 to 65°C
Humidity
• Operating: 0% to 90% non-condensing
• Storage: 5% to 95% non-condensing
Certifications
• FCC Class B
• CE Class B
• C-Tick
• DLNA
• IPv6 Ready
• Wi-Fi Certified
• Wi-Fi Multimedia (WMM)
• Compatible with Windows 8
* Maximum wireless signal rate derived from IEEE standard 802.11ac (draft) specifications which are subject to change. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual data throughput rate. Environmental factors will adversely affect wireless signal range.
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
