DIR-330EOL EOS
Wireless G VPN Router 4-Port 10/100Mbps Switch
Apraksts
D-Link answers the need for a Wireless G VPN Router with the  DIR-330.  The  DIR-330  is  an  easy-to-deploy wireless routing,  10/100  switching,  VPN,  and  frewall  solution designed  specifcally  for  the Small Offce  / Home Offce (SOHO) market  that demands  superior performance and security.
User Confgurable Interface
The DIR-330  features an  intuitive user  interface  that can easily  be  confgured  and  monitored  via  D-Link’s  Web-based  management  utility.  These  confguration  options can  be managed  through  the  default Admin  account  or you may  replace  the  “admin”  username with  name  you desire for better security.
Advanced Hardware Features
The DIR-330 can be connected to a cable or DSL modem to  share  high-speed  Internet  access.  It  also  doubles  as a  4-port  full-duplex  10/100  switch  to  connect  up  to  four Ethernet-enabled  devices. Simply  add more  switches  to expand  your  wired  network.  This  router  also  functions as  a  wireless  802.11g/802.11b  access  point  to  connect wireless devices onto your network. In addition, you can create a Virtual Private Network  (VPN) with  the DIR-330 and allow up to eight off-site or traveling users to securely access your central network  through  the  Internet at  the same time.
VPN Performance
For  optimal  VPN  confguration,  the  DIR-330  has  an integrated VPN Client and Server  to  support almost any required  VPN  policy.  This  device  has  a  hardware  VPN engine to support and manage up to 25 VPN confgurations. The DIR-330 can support IPSec, PPTP, and L2TP protocols in  Server mode  and  can  handle  pass-through  traffc  as well. Advanced VPN confguration options  include: DES/3DES/AES/Twofsh/Blowfsh encryption,  IKE/ISAKMP key management, Quick/Main/Aggressive Negotiation modes, and  VPN  authentication  support  using  the  internal  150-user database.
Enterprise-class Security
The DIR-330 can encrypt all wireless  transmission using WPA™ or WPA2™ to protect your network. It also protects your network  from online  intruders and potential attacks with  Dual  Active  Firewall  protection  using  Network Address Translation (NAT) and Stateful Packet Inspection (SPI).
With  small  businesses  becoming  increasingly  network-dependent, the need to invest in a reliable security solution is  crucial.  The D-Link Wireless G  VPN  Router  (DIR-330) offers high  return on  investment  through  robust security features,  fexible  confguration,  and  superb  network protection for small offces and home networks
Īpašības
Standards
+ IEEE  802.3
+ IEEE 802.3u
+ IEEE 802.11g
+ IEEE 802.11b
Ports
+ 4 10/100 LAN
+ 1 10/100 WAN
+ 1 USB 2.0
Firewall Mode of operation
+ Layer 3 Mode: Route Mode, NAT Mode
+ Network Address Translation (NAT)
+ Port Forwarding
+ Port Address translation (PAT)
VPN Security
+ VPN Tunnels: 8 (IPSec, PPTP, L2TP)
+ IPSec LAN-to-LAN / Remote User
+ PPTP/L2TP Server/Client
+ IPSec/PPTP/L2TP Pass-through
+ IPSec NAT-Traversal
+ DHCP over IPSec
+ Encryption transform: DES, 3DES, AES
+ XAUTH (Extended Authentication) for iPSec Authentication
Firewall Security
+ Stateful Packet Inspection (SPI)
+ Internal User Database (20 Records)
Network Service
+ Static iP Address
+ PPPoE for XDSL
+ DHCP Client for WAN Interface
+ Internal DHCP Server
+ Static Routes
+ DNS Resolving of Remote Gateway
+ DHCP over IPSec
+ Dynamic DNS
+ Russian PPPoE/PPTP (dual Access)
Device Management
Internet Explorer or later, or other Java-enabled Browsers
LEDs
+ Power
+ Status
+ LAN
+ WAN
+ WLAN
+ USB
Sertifikāti
Informācija pasūtījumam
DIR-330   Wireless VPN Router with IPSec and 4-port Switch
Attēli
DIR-330A1
View from the right
Back view
Pārlādēt
Skatiet arī
