Ātrā meklēšana
Produkta iespējas:
Wireless N300 Router
Īpašības:
  DIR-615/T4 DIR-615S
Hardware
Processor RTL8196E (400MHz) RTL8196D (620MHz)
RAM 32MB
Flash 4MB
Interfaces
10/100BASE-TX WAN port
4 10/100BASE-TX LAN ports
LEDs
POWER
WLAN
INTERNET
POWER
WLAN
WPS
INTERNET
4 LAN LEDs
Buttons
ON/OFF button to power on/power off
WPS / RESET button to set up wireless connection and restore factory default settings RESET button to restore factory default settings
WPS button to set up secure wireless connection and enable/disable wireless network
Antenna
Two non-detachable omnidirectional antennas
5dBi gain
5dBi gain
MIMO
2 x 2
Power connector
Power input connector (DC)
Software
WAN connection types
PPPoE
IPv6 PPPoE
PPPoE Dual Stack
Static IPv4 / Dynamic IPv4
Static IPv6 / Dynamic IPv6
PPPoE + Static IP / Dynamic IP (PPPoE Dual Access)
PPTP/L2TP + Static IP
PPTP/L2TP + Dynamic IP
Network functions
DHCP server/relay
Stateful/Stateless mode for IPv6 address assignment, IPv6 prefix delegation
Automatic obtainment of LAN IP address (for access point/ repeater/ client modes) + +
DNS relay
Dynamic DNS
Static IP routing
Static IPv6 routing
IGMP Proxy
RIP
Support of UPnP IGD
Support of VLAN
WAN ping respond
Support of SIP ALG
Support of RTSP
WAN reservation + +
Built-in UDPXY application
Autonegotiation of speed, duplex mode, and flow control/Manual speed and duplex mode setup for each Ethernet port
Setup of maximum TX rate for each port of the router
Firewall functions
Network Address Translation (NAT)
Stateful Packet Inspection (SPI)
IP filter
IPv6 filter
MAC filter
URL filter
DMZ
Prevention of ARP and DDoS attacks
Virtual servers
Built-in Yandex.DNS web content filtering service
VPN
IPSec/PPTP/L2TP/PPPoE pass-through
Management
Local and remote access to settings
TELNET/WEB (HTTPS, HTTP)
Bilingual web-based interface for configuration and management (Russian/English)
Support of mobile application for Android smartphones
Notification on connection problems and auto redirect to settings
Firmware update via web-based interface
Automatic notification on new firmware version
Saving/restoring configuration to/from file
Support of remote logging to remote host
Automatic synchronization of system time with NTP server and manual time/date setup
Ping utility
Traceroute utility
TR-069 client
Wireless Module Parameters
Standards
IEEE 802.11b/g/n
Frequency range
2400 ~ 2483.5MHz
Wireless connection security
WEP
WPA/WPA2 (Personal/Enterprise)
MAC filter
WPS (PBC/PIN)
Advanced functions
Support of client mode
WMM (Wi-Fi QoS)
Information on connected Wi-Fi clients
Advanced settings
Guest Wi-Fi / support of MBSSID
Smart adjustment of Wi-Fi clients
Rate limitation for wireless network/separate MAC addresses
Periodic scan of channels, automatic switch to least loaded channel
Autonegotiation of channel bandwidth in accordance with environment conditions (20/40 Coexistence) + +
Wireless connection rate
IEEE 802.11b: 1, 2, 5.5, and 11Mbps
IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
IEEE 802.11n: from 6.5 to 300Mbps (from MCS0 to MCS15)
Transmitter output power
802.11b
15dBm at 1, 2, 5.5, 11Mbps
802.11g
15dBm at 6, 9, 12, 18, 24, 36, 48, 54Mbp
802.11n
HT20/HT40
15dBm at MCS0/1/ 2/3/4/5/ 6/ 8/9/10/ 11/12/ 13/14 14dBm at MCS7/15
Receiver sensitivity
802.11b
-82dBm at 1Mbps
-80dBm at 2Mbps
-78dBm at 5.5Mbps
-76dBm at 11Mbps
-82dBm at 1Mbps
-80dBm at 2Mbps
-78dBm at 5.5Mbps
-76dBm at 11Mbps
802.11g
-91dBm at 6Mbps
-90dBm at 9Mbps
-88dBm at 12Mbps
-86dBm at 18Mbps
-83dBm at 24Mbps
-80dBm at 36Mbps
-75dBm at 48Mbps
-74dBm at 54Mbps
-85dBm at 6Mbps
-84dBm at 9Mbps
-82dBm at 12Mbps
-80dBm at 18Mbps
-77dBm at 24Mbps
-73dBm at 36Mbps
-69dBm at 48Mbps
-68dBm at 54Mbps
802.11n
HT20
-90dBm at MCS0/8
-87dBm at MCS1/9
-85dBm at MCS2/10
-82dBm at MCS3/11
-79dBm at MCS4/12
-74dBm at MCS5/13
-72dBm at MCS6/14
-70dBm at MCS7/15
HT40
-87dBm at MCS0/8
-84dBm at MCS1/9
-81dBm at MCS2/10
-78dBm at MCS3/11
-75dBm at MCS4/12
-70dBm at MCS5/13
-69dBm at MCS6/14
-67dBm at MCS7/15
HT20
-82dBm at MCS0/8
-79dBm at MCS1/9
-77dBm at MCS2/10
-74dBm at MCS3/11
-70dBm at MCS4/12
-66dBm at MCS5/13
-65dBm at MCS6/14
-64dBm at MCS7/15
HT40
-79dBm at MCS0/8
-76dBm at MCS1/9
-74dBm at MCS2/10
-71dBm at MCS3/11
-67dBm at MCS4/12
-63dBm at MCS5/13
-62dBm at MCS6/14
-61dBm at MCS7/15
Modulation schemes
802.11b
DQPSK, DBPSK, DSSS, CCK
802.11g
BPSK, QPSK, 16QAM, 64QAM with OFDM
802.11n
Physical Parameters
Dimensions
174 x 129 x 33 mm
(6.8 x 5.1 x 1.3 in)
174 x 115 x 30 mm
(6.8 x 4.5 x 1.2 in)
Weight
215 g (0.47 lb)
226 g (0.5 lb)
Operating Environment
Power
Output: 12V DC, 0.5A
Temperature
Operating: from 0 to 40 °C
Storage: from -20 to 65 °C
Humidity
Operating: from 10% to 90% (non-condensing)
Storage: from 5% to 95% (non-condensing)
Delivery Package
Router
Power adapter DC 12V/0.5A
Ethernet cable2
“Quick Installation Guide” (brochure)
Router
Ethernet cable
2Only for DIR-615/T4B.
Fiziskie raksturlielumi
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
