Ātrā meklēšana
Produkta iespējas:
Wireless AC600 Dual Band Mini Router
EOL
Apraksts:
Connect to the Internet with the D-Link DIR-516 Wireless AC600 Dual Band Mini Router. Stay connected wherever you are and share an Internet connection from your home, hotel room, or even another wireless network. The latest Wireless AC technology provide blazing connectivity to your compatible devices. The DIR-516 also remembers your connection details for you so you can simply connect devices to the DIR-516’s wireless network and it takes care of the rest.
Wireless AC for Faster Performance
The DIR-516 incorporates the latest Wireless AC600 technology for increased range and data transfer speeds to and from compatible Wi-Fi devices. Using dual bands to bypass radio congestion and interference, the DIR-516 can deliver a total of 2.4 GHz (up to 150 Mbps) or 5 GHz (up to 433 Mbps). You can even configure a guest zone to give visitors Internet access without giving them access to the rest of your network.
Maximum Portability
The DIR-516’s small, lightweight, design let’s you conveniently set up an Internet connection on the go. Take advantage of the the Wireless AC600 Dual Band Mini Router’s compact size by carrying it in your bag or laptop case. Instantly set up a connection in libraries, cafes, or at home so you stay connected wherever you are.
Easy to Set Up, Easy to Use
Sharing your Internet connection doesn’t have to be a complicated process. Just open a web browser to access the utility and follow the instructions to get started. Create a secure network with the touch of a button using Wi-Fi Protected Setup (WPS), which instantly creates a secure connection to a new device without the need to enter settings or passwords.
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
