Ātrā meklēšana
Produkta iespējas:
Wi-Fi AC750 Portable Router and Charger
Apraksts:
Connect, share, and charge your mobile devices anytime, anywhere, with D-Link’s DIR-510L Wi-Fi AC750 Portable Router and Charger. Share files, stream media, and browse the Internet with the superb speed and performance provided by the latest Wireless AC technology. Simply connect your laptop, smartphone, or tablet to the DIR-510L’s wireless network and it will take care of the rest. With the built-in high-capacity rechargeable battery, this mobile power station lets your devices perform strong all day long.
Wireless AC for Breakthrough Performance
The DIR-510L incorporates the latest Wireless AC750 technology for unprecedented range and data transfer performance to and from compatible Wi-Fi devices. By using dual bands to bypass radio congestion and interference, the router can deliver a total of 750 Mbps using the combined bandwidth of its 2.4 GHz and 5 GHz bands. Moreover, each band can operate as a separate Wi-Fi network, giving you the ability to customize your network according to your connectivity needs. You can even configure a guest zone to give visitors Internet access without giving them access to the rest of your network. Combined with support for Universal Plug and Play (uPnP) and a built-in DLNA server, you can stream your multimedia collection smoothly and securely across all your devices and appliances, including smart TVs, game consoles, and media PCs.*
mydlink SharePort™ – Share On the Go
Sharing audio, videos, and photos is a breeze with the DIR-510L. Using the mydlink SharePort and SharePort Mobile apps for mobile devices, you can upload, download, and stream multimedia and documents to and from a USB drive attached to your DIR-510L, from anywhere in the world! Simply download the app, register for a free mydlink account, connect to your DIR-510L, and you can start sharing your media files with your friends and family as long as you have access to the Internet.
Your Mobile Power Station
The DIR-510L’s built-in high-capacity 4000 mAh rechargeable battery not only powers the device itself, it also keeps your gadgets charged and ready to go. The device provides two USB ports so you can charge a device and share files from a USB drive at the same time. You no longer have to worry about your smartphone’s battery running out of juice while on-the-move. Simply connect your smartphone or high-power devices like iPads to the USB port to start charging anywhere, anytime.**
Easy to Set Up, Easy to Use
The DIR-510L includes a user-friendly interface that stores your connection details for you so you only have to enter them once. Whether you’re connected via your 3G/4G adapter for mobile Internet or to the Wi-Fi hotspot of your favorite cafe, the DIR-510L helps you keep all of your devices connected, automatically!
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
