Ātrā meklēšana
Produkta iespējas:
Wireless AC1200 Dual-Band Gigabit Cloud Router USB 3.0
Apraksts:
The DIR-860L Wireless AC1200 Dual-Band Gigabit Cloud Router USB 3.0 lets you easily connect, control, and monitor a network using the future of wireless technology, today. It’s mydlink Cloud-enabled and supports the SharePort Mobile app to stream and share your media files.
Fast and Reliable Home Networking
The D-Link DIR-860L Wireless AC1200 Dual-Band Gigabit Cloud Router USB 3.0 creates a blazing fast home network that connects all of your computers and mobile devices to your broadband Internet connection. Concurrent dual-band 802.11ac brings you the future of high-bandwidth wireless connectivity allowing you to stream HD video, make Internet calls, and surf the Internet from every corner of your home without interruption. Gigabit Ethernet ports provide high-speed wired connections for up to four PCs or other devices. It’s stylish, easy-to-use, and comes IPv6-ready for a reliable network today and tomorrow.
Use mydlink to Monitor Your Network
The Wireless AC1200 Dual-Band Gigabit Cloud Router USB 3.0 is mydlink Cloud-enabled, so you can effortlessly access and view your network no matter where you are. See who is connected to your router, change settings, or block someone from using your network connection, all from any Internet connected PC, or an iOS or Android mobile device. Parents can monitor what sites their children are visiting, and can stay informed and in control on the go.
File Sharing Right at Your Fingertips
The SharePort Mobile app allows you to connect a USB storage device to the DIR-860L and instantly share documents, movies, pictures, and music with mobile devices. You can put your music library on a USB drive and share it with your entire home. You can show photos on the  living room TV while a family member watches a movie on their mobile device. You can stream media files to multiple devices without interruption, or save them to your device for offline playback. The intuitive interface lets anyone immediately connect to a variety of entertainment options stored securely on your own storage device.
Smooth Streaming with Wireless AC
The DIR-860L uses the latest Wireless AC technology, which can provide transfer rates of up to 1.2Gbps* (900AC + 300N). The router operates on both the 2.4 GHz and 5 GHz wireless bands at the same time using concurrent dual-band technology and four internal antennas. This allows you to browse the web, chat and email using the 2.4 GHz band, while simultaneously streaming digital media, playing online games, or making Internet phone calls on the 5 GHz band.
Easy to Set Up and Use
Get the DIR-860L up and running in no time right from your couch using the QRS (Quick Router Setup) Mobile app on your iOS or Android device. Simply plug in the router, open the app, and follow a few easy steps to get your home network connected without having to touch a computer. You can also set up a secure network with the touch of a button using Wi-Fi Protected Setup. Simply press the WPS button to instantly establish a secure connection to a new device. If you have additional mydlink cloud products, you can take advantage of mydlink Zero Configuration. Simply connect your mydlink-enabled device to the DIR-860L and the router will automatically link it to your mydlink account with no configuration required.
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
