Ātrā meklēšana
Produkta iespējas:
Wireless N600 Dual Band Gigabit Router with 3G/LTE Support and USB Port
Īpašības:
Processor
• RTL8197D (660 MHz)
RAM
• 64MB, DDR2
Flash
• 8MB, SPI
LEDs
• POWER
• WPS
• INTERNET
• 2.4GHz
• 5GHz
• 4 LAN LEDs
• USB
Buttons
• ON/OFF button to power on/power off
• RESET button to restore factory default settings
• WPS button to set up secure wireless connection and enable/disable wireless network
Antenna
• Two internal dual band antennas (4dBi gain for 2.4GHz and 6dBi gain for 5GHz)
MIMO
• 2 x 2
Power connector
• Power input connector (DC)
Software
WAN connection types
• LTE
• 3G
• PPPoE
• IPv6 PPPoE
• PPPoE Dual Stack
• Static IP / Dynamic IP
• Static IPv6 / Dynamic IPv6
• PPPoE + Static IP
• PPPoE + Dynamic IP
• PPTP/L2TP
• PPTP/L2TP + Static IP
• PPTP/L2TP + Dynamic IP
Network functions
• Support of IEEE 802.1X for Internet connection
• DHCP server/relay
• DHCPv6 server (Stateful/Stateless), IPv6 prefix delegation
• DNS relay
• Support of DNSv6 AAAA records
• Dynamic DNS
• Static IP routing
• Static IPv6 routing
• IGMP Proxy
• RIP
• Support of UPnP IGD
• Support of VLAN
• WAN ping respond
• Support of SIP ALG
• Support of RTSP
• WAN reservation
• Autonegotiation of speed, duplex mode, and flow control/Manual speed and duplex mode
• setup for each Ethernet port
• Setup of maximum TX rate for each port of the router
• Built-in UDPXY application
• Built-in XUPNPD application
Firewall functions
• IP filter
• IPv6 filter
• MAC filter
• URL filter
• DMZ
• Prevention of ARP and DDoS attacks
• Virtual servers
• Built-in Yandex.DNS web content filtering service
VPN
• IPSec/PPTP/L2TP/PPPoE pass-through
USB interface functions
• USB modem
  - Auto connection to available type of supported network (4G/3G/2G)
  - Auto configuration of connection upon plugging in USB modem
• Enabling/disabling PIN code check, changing PIN code1
  - USB storage
  - File browser
  - Print server
  - Access to storage via accounts
  - Built-in Samba server
  - Built-in FTP server
  - Built-in DLNA server
  - Built-in Transmission torrent client; uploading/downloading files from/to USB storage
Management
• Local and remote access to settings through TELNET/WEB (HTTP/HTTPS)
• Multilingual web-based interface for configuration and management
• Support of logging to remote host/connected USB storage
• Ping function
• Traceroute utility
• TR-069 client
Wireless Module Parameters
Standards
• IEEE 802.11a/n
• IEEE 802.11b/g/n
Frequency range
• 2400 ~ 2483.5MHz
• 5150 ~ 5350MHz
• 5650 ~ 5725MHz
Wireless connection security
• WEP
• МАС filter
• WPS (PBC/PIN)
Advanced functions
• Support of client mode
• WMM (Wi-Fi QoS)
• Information on connected Wi-Fi clients
• Advanced settings
• Smart adjustment of Wi-Fi clients
• Guest Wi-Fi / support of MBSSID
• Limitation of wireless network rate
• Periodic scan of channels, automatic switch to least loaded channel
Wireless connection rate
• IEEE 802.11a: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
• IEEE 802.11b: 1, 2, 5.5, and 11Mbps
• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
• IEEE 802.11n (2.4GHz/5GHz): from 6.5 to 300Mbps (from MCS0 to MCS15)
Transmitter output power
• 802.11a (typical at room temperature 25 °C)
  12.5dBm (+/-1.5dB)
• 802.11b (typical at room temperature 25 °C)
  16dBm (+/-1.5dB)
• 802.11g (typical at room temperature 25 °C)
  14.5dBm (+/-1.5dB)
• 802.11n (typical at room temperature 25 °C)
  HT20
  14dBm (+/-1.5dB) MCS6/7 (2.4GHz)
  11.5dBm (+/-1.5dB) MCS6/7 (5GHz)
  HT40
Receiver sensitivity
• 802.11a (typical at PER = 10% (1000-byte PDUs) at room temperature 25 °C)
  -65dBm at 54Mbps
• 802.11b (typical at PER = 8% (1000-byte PDUs) at room temperature 25 °C)
  -82dBm at 1Mbps
  -78dBm at 5.5Mbps
  -76dBm at 11Mbps
• 802.11g (typical at PER = 10% (1000-byte PDUs) at room temperature 25 °C)
  -82dBm at 6Mbps
  -81dBm at 9Mbps
  -79dBm at 12Mbps
  -77dBm at 18Mbps
  -74dBm at 24Mbps
  -70dBm at 36Mbps
  -66dBm at 48Mbps
  -65dBm at 54Mbps
• 802.11n (typical at PER = 10% (1000-byte PDUs))
  HT20
  -82dBm at MCS0/8
  -79dBm at MCS1/9
  -77dBm at MCS2/10
  -74dBm at MCS3/11
  -70dBm at MCS4/12
  -66dBm at MCS5/13
  -65dBm at MCS6/14
  -64dBm at MCS7/15
  HT40
  -79dBm at MCS0/8
  -76dBm at MCS1/9
  -74dBm at MCS2/10
  -71dBm at MCS3/11
  -67dBm at MCS4/12
  -63dBm at MCS5/13
  -62dBm at MCS6/14
  -61dBm at MCS7/15
Modulation schemes
• 802.11a: BPSK, QPSK, 16QAM, 64QAM with OFDM
• 802.11g: BPSK, QPSK, 16QAM, 64QAM with OFDM
• 802.11n: BPSK, QPSK, 16QAM, 64QAM with OFDM
Physical Parameters
Dimensions (L x W x H)
• 194 x 59 x 120 mm (7.7 x 2.3 x 4.7 in)
Weight
• 300 g (0.66 lb)
Operating Environment
Power
• Output: 12V DC, 1.2A
Temperature
• Operating: from 0 to 40 °C
• Storage: from -20 to 65 °C
Humidity
• Operating: from 10% to 90% (non-condensing)
• Storage: from 5% to 95% (non-condensing)
Delivery Package
• Router DIR-825
• Power adapter DC 12V/1.2A • Ethernet cable
Supported USB modems2
GSM
• Alcatel X500
• D-Link DWM-152C1
• D-Link DWM-156A6
• D-Link DWM-156A7
• D-Link DWM-156C1
• D-Link DWM-157B1
• D-Link DWM-157B1 (Velcom)
• D-Link DWM-158D1
• D-Link DWR-710
• Huawei E150
• Huawei E1550
• Huawei E156G
• Huawei E160G
• Huawei E169G
• Huawei E171
• Huawei E173 (Megafon)
• Huawei E220
• Huawei E352 (Megafon)
• Prolink PHS600
• ZTE MF112
• ZTE MF192
• ZTE MF626
• ZTE MF627
• ZTE MF652
• ZTE MF667
• ZTE MF668
• ZTE MF752
LTE
• Huawei E3131
• Huawei E3272
• Huawei E3351
• Huawei E3372
• Huawei E367
• Huawei E392
• Megafon M100-1
• Megafon M100-2
• Megafon M100-3
• Megafon M100-4
• Megafon M150-1
• Megafon M150-2
• MTS 824F
• МТS 827F
• Quanta 1K6E (Beeline 1K6E)
• Yota LU-150
• Yota WLTUBA-107
• ZTE MF823
• ZTE MF827
Smartphones in USB tethering mode
• Some models of Android smartphones
1 For GSM USB modems and some models of LTE USB modems.
2 The manufacturer does not guarantee proper operation of the router with every modification of the firmware of USB modems.
Fiziskie raksturlielumi
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
