Ātrā meklēšana
Produkta iespējas:
Wireless N600 Dual Band Gigabit Router with 3G/LTE Support and USB Port
Apraksts:
USB Port
The router is equipped with a USB port for connecting a USB modem, which can be used to establish connection to the Internet. Inaddition, to the USB port of the router you can connect a USB storage device, which will be used as a network drive, or a printer.
Wireless Interface
Using the DIR-825 device, you are able to quickly create a high-speed wireless network at home or in your office, which lets computersand mobile devices access the Internet virtually anywhere (within the operational range of your wireless network). Simultaneous activityof 2.4GHz band and 5GHz band allows performing a wide range of tasks. The router can operate as a base station for connectingwireless devices of the standards 802.11a, 802.11b, 802.11g, and 802.11n (at the wireless connection rate up to 600Mbps1).
Secure Wireless Connection
The router supports multiple functions for the wireless interface: several security standards (WEP, WPA/WPA2), MAC address filtering,WPS, WMM.In addition, the device is equipped with a button for switching the Wi-Fi network off/on. If needed, for example, when you leave home,you can easily switch the router’s WLAN by pressing the button, and devices connected to the LAN ports of the router will stay online.
Support of guest Wi-Fi network allows you to create a separate wireless network with individual security settings and maximum ratelimitation. Devices connected to the guest network will be able to access the Internet, but will be isolated from the devices andresources of the router's LAN.
Smart adjustment of Wi-Fi clients is useful for networks based on several D-Link access points or routers – when the smart adjustmentfunction is configured on each of them, a client always connects to the access point (router) with the highest signal level.
Airgain Built-in Antennas
The router is equipped with Airgain built-in omnidirectional antennas. In spite of their compact size, such antennas can compete andeven exceed performance of traditional whip antennas. Airgain antennas provide high gain (4dBi for 2.4GHz band and 6dBi for 5GHzband) and circular pattern in both horizontal and vertical plane; due to this, Airgain antennas show excellent performance in anydirection, increase wireless network range and minimize occurrence of blind spots.
Security
The wireless router DIR-825 includes a built-in firewall. The advanced security functions minimize threats of hacker attacks, preventunwanted intrusions to your network, and block access to unwanted websites for users of your LAN.Built-in Yandex.DNS service protects against malicious and fraudulent web sites and helps to block access to adult content onchildren's devices.
Easy configuration and update
You can configure the settings of the wireless router DIR-825 via the user-friendly web-based interface (the interface is available inseveral languages).You can simply update the firmware: the router itself finds approved firmware on D-Link update server and notifies when ready to installit.
1Up to 300Mbps for 2.4GHz and up to 300Mbps for 5GHz
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
