Ātrā meklēšana
Produkta iespējas:
Wireless N600 Dual Band Gigabit Cloud Router
Apraksts:
The DIR-826L Wireless N600 Dual-band Gigabit Cloud Router is an attractive, high-performance router that features Wireless N and Gigabit Ethernet ports. The router is also mydlink-enabled which enables you to remotely access your router with a mobile device.
A Fast and Reliable Dual-band Network
The D-Link DIR-826L Wireless N600 Dual-band Gigabit Cloud Router creates a high-speed network for connecting all of your computers and mobile devices to your broadband Internet connection. 802.11n provides wireless speeds up to 300 Mbps1 for fast file transfers and smooth online gaming, and a built-in power amplifier extends wireless coverage to every corner of your home. Concurrent dual-band technology allows you to check e-mail and browse the Internet using the 2.4 GHz band while simultaneously streaming digital media on the 5 GHz band. Everyone can get the throughput they need for any kind of online activity.
mydlink-enabled
The Wireless N600 Dual-band Gigabit Cloud Router allows you to use the mydlink web portal and mobile apps to effortlessly access, view, and manage devices on your home network no matter where you are. See who’s connected to your router, change settings, or block someone from using your network connection, all from any Internet-connected PC, or an iOS or Android mobile device. Parents can monitor what sites their children are visiting, and can stay informed and in control on the go.
Gigabit Connectivity with QoS
The four Gigabit LAN ports on the back of the DIR-826L offer lightning quick wired connection speeds that can provide you with smooth streaming of HD video, flawless Internet phone calls, and lag-free online gaming. The Gigabit WAN port sends data to the wireless interface at full speed so that wirelessly connected devices can attain incredible performance. An advanced QoS engine analyzes and separates your wired and wireless traffic into multiple data streams so applications like VoIP, video streaming, and online gaming can be given priority.
Share and Stream Your Files
The Wireless N600 Dual-band Gigabit Cloud Router lets you create a shared storage space, making it easy to share files between computers and devices connected to your network. Plug in a USB hard drive to stream your library of videos and music to your laptop, or use a USB flash drive to share presentation files with other team members. An easy to use SharePort™ Mobile app allows you to back up photos and videos stored your device. You can even create separate accounts to control access to the USB drive, so you can share your music with everyone but keep your personal files private.
Easy to Set Up and Secure
Get the DIR-826L up and running in no time right from your couch using the QRS (Quick Router Setup) Mobile app on your iOS or Android device. Simply plug in the router, open the app, and follow a few easy steps to get your home network connected without having to touch a computer. You can also set up a secure network with the touch of a button using Wi-Fi Protected Setup. Simply press the WPS button to instantly establish a secure connection to a new device. Protect your network with WPA/WPA2 wireless encryption and a built-in dual-active firewall (SPI and NAT) so you can shop online and do your online banking with confidence.
Modern, Artistic Design
The unique shape and the compact size of the DIR-826L mean that you don’t need to hide another piece of tech clutter in your home. With all ports and connectors discreetly hidden on the back of the device, you can proudly display your router as a seamless part of any modern home.
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
