Ātrā meklēšana
Produkta iespējas:
AC1200 Wi-Fi Range Extender
EOL
Īpašības:
Device Interfaces
• 802.11ac/n/g/b/a Wireless LAN
• 10/100/1000 Gigabit Ethernet Port
• Reset Button
• WPS Button
LEDs
• Status/WPS
• 3 Segment Wi-Fi Signal Strength Indicator
Standards
• IEEE 802.11ac
• IEEE 802.11n
• IEEE 802.11g
• IEEE 802.11b
• IEEE 802.11a
• IEEE 802.3ab
Antennas
• Two external antennas
Data Signal Rate
• 2.4 GHz: Up to 300 Mbps1
• 5 GHz: Up to 867 Mbps1
Plug Type
• Region dependent
Functionality
Wireless Security
• Wi-Fi Protected Access (WPA/WPA2)
• WPS (PBC)
Advanced Features
• D-Link One-Touch Extender Setup
Device Management
• Supports QRS Mobile app for iPhone, iPad, iPod touch, and Android mobile devices
• Web UI
Physical
Dimensions
• 120 x 59 x 42 mm (4.72 x 2.32 x 1.65 inches)
Weight
• 139 grams (4.9 ounces)
Power
• Input: 110 to 240 V AC, 50/60 Hz
Temperature
• Operating: 0 to 40 °C (32 to 104 °F)
• Storage: -20 to 65 °C (-4 to 149 °F)
Humidity
• Storage: 5% to 95% non-condensing
Certifications
• FCC
• IC
• CE 2
• C-Tick
• EMI/EMC
• UL
• Wi-Fi Certified
1 Maximum wireless signal rate derived from IEEE Standard 802.11ac and 802.11n specifications. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffic, building materials and construction, and network overhead, may lower actual data throughput rate. Environmental factors will adversely affect wireless signal range.
Fiziskie raksturlielumi
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
