Ātrā meklēšana
Produkta iespējas:
Wireless N Exterior Access Point
Īpašības:
Device Interfaces
• 802.11n/g/b
• Two 10/100 Ethernet ports (one supports PoE)
• Reset button
• Grounding wire connector
LEDs
• Power
• LAN
• Wireless Signal Strength
Antenna
• Sector antenna with 10dBi gain
Standards
• IEEE 802.11b/g/n
• IEEE 802.3
• IEEE 802.3u
Frequency band
• 802.11b: from 2.4 GHz to 2.497GHz
• 802.11g: from 2.4 GHz to 2.4835GHz
• 802.11n: from 2.4 GHz to 2.4835GHz
Wireless speed
• 802.11b: 11, 5.5, 2, 1 Mbit/s
• 802.11g: 54, 48, 36, 24, 18, 12, 9, 6 Mbit/s
• 802.11n:
  MCS GI=800ns GI=400ns
20MHz 40MHz 20MHz 40MHz
  0 6,5 13,5 7,2 15
  1 13 27 14,4 30
  2 19,5 40,5 21,7 45
  3 26 54 28,9 60
  4 39 81 43,3 90
  5 52 108 57,8 120
  6 58,5 121,5 65,0 135
  7 65 135 72,2 150
  8 13 27 14,444 30
  9 26 54 28,889 60
  10 39 81 43,333 90
  11 52 108 57,778 120
  12 78 162 86,667 180
  13 104 216 115,556 240
  14 117 243 130 170
  15 130 270 144,444 300
The output power of the transmitter
• IEEE 802.11b:
  28 ±2 dBm at 1, 2, 5,5, 11 Mbit/s
• IEEE 802.11g:
  26 ±2 dBm at 6-36 Mbit/s
  24 ±2 dBm at 48 Mbit/s
  23 ±2 dBm at 54 Mbit/s
• IEEE 802.11n:
  2.4GHz/HT-20
  26 ±2 dBm at MCS0/8,1/9,2/10,3/11
  25 ±2 dBm at MCS4/12
  24 ±2 dBm at MCS5/13
  23 ±2 dBm at MCS6/14
  22 ±2 dBm at MCS7/15
  2.4GHz/HT-40
  25 ±2 dBm at MCS0/8,1/9,2/10
  25 ±2 dBm at MCS3/11
  24 ±2 dBm at MCS4/12
  23 ±2 dBm at MCS5/13
  22 ±2 dBm at MCS6/14
  21 ±2 dBm at MCS7/15
Receiver sensitivity
• IEEE 802.11b:
  -96 ±2 dBm at 1 Mbit/s
  -94 ±2 dBm at 2 Mbit/s
  -91 ±2 dBm at 5.5 Mbit/s
  -88 ±2 dBm at 11 Mbit/s
• IEEE 802.11g:
  -90 ±2 dBm at 6 Mbit/s
  -89 ±2 dBm at 9 Mbits/s
  -88 ±2 dBm at 12 Mbit/s
  -86 ±2 dBm at 18 Mbit/s
  -84 ±2 dBm at 24 Mbit/s
  -80 ±2 dBm at 36 Mbit/s
  -76 ±2 dBm at 48 Mbit/s
  -74 ±2 dBm at 54 Mbit/s
• IEEE 802.11n:
  2.4GHz/HT-20
  -90 ±2 dBm at MCS0/8
  -88 ±2 dBm at MCS1/9
  -86 ±2 dBm at MCS2/10
  -82 ±2 dBm at MCS3/11
  -78 ±2 dBm at MCS4/12
  -75 ±2 dBm at MCS5/13
  -74 ±2 dBm at MCS6/14
  -72 ±2 dBm at MCS7/15
  2.4GHz/HT-40
  -85 ±2 dBm at MCS1/9
  -83 ±2 dBm at MCS2/10
  -80 ±2 dBm at MCS3/11
  -76 ±2 dBm at MCS4/12
  -72 ±2 dBm at MCS5/13
  -71 ±2 dBm at MCS6/14
  -69 ±2 dBm at MCS7/15
Operation modes
• AP
• WDS
• WDS access point
• Wireless client
• Repeater
• WISP Repeater
• WISP Client Router
Network management
• Web interface
• HTTP - Secure HTTP (HTTPS)
• SNMP v1, v2c, v3
Security
• WPA2-Personal/Enterprise
• WPA-Personal/Enterprise
• 64/128-bit WEP encryption
• 802.1X
SSID/VLAN
• Supports up to 8 SSID/VLAN
Fiziskie raksturlielumi
Dimensions
• 118 x 56 x 195mm
Weight
• 305g
Operating voltage
• 48VDC ±10% for PoE
Max. power consumption
• 13.5W
Temperature
• Operating: -20° to 60°C
• Storage: -20° to 85°C
Humidity
• Operating: 10% to 90% (non-condensing)
• Storage: 5% to 95% (non-condensing)
ESD-protection
• 15kV
Certifications
• CE
• FCC
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
