DHP-P700AVEOL EOS
PowerLine AV2 2000 Gigabit Passthrough Adapter
Apraksts
The D-Link DHP-P700AV PowerLine AV2 2000 Gigabit Passthrough Adapter, compliant with the HomePlug AV2 standard, uses your home’s existing electrical wiring to create a network or extend your existing one*. It supports up to 2000 Mbps data transfer speeds** and transforms every power outlet into a potential network connection. Simply put, the DHP-P700AV gives you the freedom to access digital media devices, game consoles, print servers, computers, and network storage devices from anywhere in your home.
Convenient Setup and Secure Operation
Compliance with the IEEE 1901/HomePlug AV2 standard and backward compatible with the HomePlug AV ensure that the DHP-P700AV can be used with older PowerLine devices. For convenient setup, a secure connection can be quickly set up with the push of a button. The adapter implements 128?bit AES data encryption to protect the network from unauthorized wiretapping. In addition, the DHP-P700AV includes a noise filter in the power outlet can reduces interference to maximize throughput and improve overall performance.
Power Saving Mode
The DHP-P700AV incorporates a power saving mode that automatically places the adapter in sleep mode if no data transmission or reception occurs over a certain period of time, reducing power usage. This helps you save energy automatically without sacrificing performance.
Quality of Service (QoS)
The DHP-P700AV supports Quality of Service (QoS) which prioritizes Internet traffic by type, letting you enjoy streaming multimedia with less stutter while simultaneously browsing the Web and downloading files. This allows for smooth streaming of Internet Protocol Television (IPTV), HD video, and lag-free online gaming.
* Power outlets and electrical wiring must all be part of the same electrical system. Certain electrical conditions in your home, such as wiring condition and configuration, may affect the performance of this product. Additional D-Link PowerLine AV series products are required to add new devices to the network. A minimum of two D-Link PowerLine AV series products are required to create a network. Connecting this product to a power strip with a surge protector may adversely affect the performance of this product. For best results, plug the adapter directly into a wall outlet.
** Maximum throughput is based on theoretical transmission PHY rate. Actual data throughput will vary. Network conditions and environmental factors, including volume of traffic and network overhead, may lower actual data throughput rate. Interference from devices that emit electrical noise, such as vacuum cleaners and hair dryers, may adversely affect the performance of this product. This product may interfere with devices such as lighting systems that have a dimmer switch or a touch-sensitive on/off feature, short wave radios, or other PowerLine devices that do not follow the HomePlug AV standard.
Īpašības
Interfaces
• One Gigabit Ethernet port
• Passthrough (country-dependent)
• Power plug (country-dependent)
LEDs
• Power
• PowerLine
• Ethernet
Buttons
• Reset
• Simple Connect
Standards and Functions
• IEEE 802.3
• IEEE 802.3x Flow Control
• Auto negotiation
• Auto MDI/MDIX
• HomePlug AV2
• IEEE 1901
• Power saving mode
• QoS
• MIMO technology
Security
• 128?bit AES data encryption
PowerLine Modulation Scheme
• OFDM Symbol Modulation
Powerline Frequency Band
• 2 MHz to 86 MHz
Data Rate
• PowerLine: up to 2000 Mbps (PHY rate)**
• Ethernet: 10/100/1000 Mbps
Physical Parameters
Weight
• 210 g
Dimensions (L x W x H)
• 60 x 37.75 x 119 mm
Power Input
• 100-250 V AC, 50/60 Hz, 16A
Passthrough Power Socket
• 250 V/16 A Maximum
Power Consumption
• Maximum: 4.36 W
• Network Standby: 3.75 W
• Power Saving: 0.22 W
Temperature
• Operating: 0° to 40°C
• Storage: -20° to 65°C
Humidity
• Storage: 5% to 95% non-condensing
Certificates
• CE
• FCC
• CE/LVD
• UL
Sertifikāti
Informācija pasūtījumam
