Ātrā meklēšana
Produkta iespējas:
Two DHP-P308AV PowerLine Adapters Kit
Īpašības:
Interfaces
• Powerline: power connector (depending on country)
• Passthrough: power connector (depending on country)
• Ethernet: Fast Ethernet port with RJ-45
Standards
• IEEE 802.3
• IEEE 802.3u
• IEEE 1901
• HomePlug AV
Security
• 128-bit AES Data Encryption
LEDs
• Power
• PowerLine
• Ethernet
PowerLine Modulation Scheme
• OFDM Symbol Modulation
Powerline Frequency Band
• 2 to 30 MHz
Data Rate
• PowerLine: 200 Mbps (PHY rate)**
• Ethernet: 10/100 Mbps (auto negotiation)
Physical Parameters
Dimensions
• 91.5 x 62 x 35.5 mm
Weight
• With EU plug: 156 g
• With UK plug: 158 g
Saving energy
• Support power saving mode
Temperature
• Operating: 0° to 40°C
Humidity
Certifications
• CE LVD
• FCC
• UL
• CE EMC Class B
• RoHS
• ErP
Electrical outlet (depending on country)
• Electrical outlet type EU: 250 V/16 A max
• Electrical outlet type UK: 250 V/13 A max.
• Electrical outlet type FR: 250 V/16 A max
• Electrical outlet type US: 125 V/12 A max
• The electrical socket type AU: 250 V/10 A max
** PowerLine AV+ products feature a more efficient processor than current 200 Mbps PowerLine AV products to provide better performance for users.
Maximum throughput is based on theoretical transmission PHY rate. Actual data throughput will vary. Network conditions and environmental factors, including volume of traffic and network overhead, may lower actual data
throughput rate. Interference from devices that emit electrical noise, such as vacuum cleaners and hair dryers, may adversely affect the performance of this product. This product may interfere with devices such as lighting
systems that have a dimmer switch or a touch-sensitive on/off feature, short wave radios, or other Powerline devices that do not follow the HomePlug AV standard.
Fiziskie raksturlielumi
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
