DHP-309AV
Two DHP-308AV PowerLine AV+ Adapters Kit
Apraksts
The DHP-309AV Powerline AV+ Mini Starter Kit is compliant with the HomePlug AV standard and uses your home’s existing electrical wiring to create a network or extend your existing network*. It turns any power outlet into a network connection to access digital media devices, game consoles, print servers, computers, and network storage devices throughout your home. The DHP-309AV Powerline AV+ Mini Starter Kit includes two DHP-308AV mini adapters, allowing you to create a PowerLine home network.
PowerLine AV+ for Bandwidth-Intensive Applications
PowerLine AV+ technology enables to deliver data at speeds up to 200 Mbps, that is higher than regular PowerLine AV products. This rapid transmission speed makes it ideal for bandwidth-intensive applications, which guarantees smooth HD video streaming, VoIP calls, and lag-free online gaming experiences. Create a network capable of Internet surfing, media streaming, and file sharing, all using your home’s existing electrical wiring.
Convenient Setup and Secure Operation
DHP-309AV plugs directly into a power outlet, and does not require any additional cables. Extend your home network by connecting multiple devices in the farthest corners of your home. Share the Internet connection from your study with the media center in your living room, or connect computers in different rooms to share files, all without installing new cabling. For convenient setup, an encryption key can be quickly configured with the push of a button. The adapter implements 128-bit AES data encryption to protect the network from unauthorized wire-tapping and keeping your network activity safe from intruders. With the simple Plug-and-Play installation, DHP-309AV adapter is a perfect solution to create a home network.
Saves Power Automatically
DHP-309AV supports power saving mode to comply with European Directive on the use of energy-using products (EuP). If no data transmission or reception occurs over a certain period of time, the adapters will automatically go into sleep mode, reducing power usage by more than 70% and allowing you to save energy automatically, without sacrificing performance.
Quality of Service (QoS)
A QoS engine will analyze and separate the traffic of the DHP-309AV into multiple data streams. This allows for smooth streaming of Internet Protocol Television (IPTV), HD video, and lag-free online gaming because the most demanding data streams are automatically given priority.
DHP-309AV PowerLine AV 500 Mini Starter Kit
The DHP-308AV is also available in a starter kit that provides a complete PowerLine solution. The DHP-309AV PowerLine AV 500 Mini Starter Kit features two DHP-308AV adapters, give you everything you need to create and start using a PowerLine network in your home right away.
Īpašības
PowerLine Interface
• Power plug (country-dependent)
Ethernet Interface
• Fast Ethernet Port
• RJ-45 Connector
Standards
• IEEE 802.3
• IEEE 802.3u
• HomePlug AV
• IEEE 1901
Security
• 128-bit AES Data Encryption
LEDs
• Power
• Ethernet
• PowerLine
Powerline Modulation Scheme
• OFDM Symbol Modulation
Powerline Frequency Band
• 2 MHz to 68 MHz
Data Rate
• PowerLine: More than 200 Mbps (PHY rate)**
• 10/100 Mbps (autonegotiation)
Sertifikāti
Informācija pasūtījumam
DHP-309AV  Two DHP-308AV PowerLine AV+ Adapters Kit
Attēli
DHP-309AV/Bx
View from the right
DHP-309AV
Pārlādēt
Skatiet arī
