DUB-1342EOL EOS
3-Port USB 3.0 Hub with Card Reader
Apraksts
Blazing USB 3.0 Speed
Connect to up to 3 USB 3.0 devices at blazing speeds of up to 5 Gbps - up to 10 times faster than USB 2.0. You can back up your photos, music, and HD movies to an external storage device faster than ever before, making backups of large files and folders quick and convenient. The DUB-1342 is a very good choice for connecting external storage to your computer.
Connect All Your Peripherals
Backward compatibility with USB 2.0 and USB 1.1 means that you can connect any USB device to the DUB-1342. With 3 ports, the DUB-1342 can also support simultaneous operation of USB devices. If you need more ports, you can connect additional USB hubs to connect up to 127 devices.
Transfer Content from Mobile Devices
The five card reader slots allow you to easily transfer content such as music, photos, videos, and data from your mobile devices to your computer at speeds of up to 480 Mbps. The supported card types include CF, MD, MS, SD, MMC, and microSD. Additional types such as miniSD, miniSDHC, MMCmobile, MMCmicro, RS MMC, and Memory Stick Micro (M2) can also be supported by using a card adapter. The high-quality Smart Card reader enables you to use password-free login to a computer, or secure online shopping and banking.
Īpašības
Interface
• 3 USB 3.0 ports
• 5 card reader slots
Standards
• USB specification version 3.0*
• USB specification version 2.0*
• USB specification version 1.1*
• OHCI (Open Host Controller Interface)
• xHCI (Enhanced Host Controller Interface)
Data rates
• SuperSpeed: 4.8 Gbps**
• Hi-Speed: 480 Mbps
• Full Speed: 12 Mbps
• Low Speed: 1.5 Mbps
Connectivity
• Up to 127 devices by cascading multiple hubs
System requirements
• Available USB port
• Operating System: Windows 7/Vista/XP/Server 2008, Mac OS X, Linux
• Hard Disk Space: 50 MB and up
Supplied power
• Maximum 900 mA per port (with external AC adapter)
Power
• External power adapter 5 V/3 A
Dimensions
• 150 x 41 x 41 mm
Weight
• 99 grams
Operating temperature
• 0 to 40 C
Storage temperature
• -20 to 60 C
Operating humidity
• 0% to 80% (non-condensing)
Package contents
• D-Link 3-Port USB 3.0 Hub with Card Reader
• Power adapter
• Quick Installation Guide
• CD-Rom with QIG and driver
Certifications
• FCC
• CE
• C-Tick
* Both the host and client device must support the same data rate in order to transfer data at that rate.
Sertifikāti
Informācija pasūtījumam
DUB-1342 3-Port USB 3.0 Hub with Card Reader
