Produkta iespējas:
Wireless N Day/Night Network Camera EOL |
Īpašības:
Camera
Camera Hardware Profile • 1/5” VGA progressive CMOS sensor • Fixed length 3.15 mm • Aperture F2.8 • Angle of view • (H) 45.3° • (V) 34.5° • (D) 54.9° • Exposure Time: 1/3.75 to 1/14,640 sec. • 4X digital zoom • Minimum object distance: 500 mm • Built-in microphone • 5 meter IR illumination distance • Minimum illumination: 0 lux with IR LEDs on • Built-in Infrared-Cut Removable (ICR) Filter module Image Features • Configurable image size, quality, and frame rate • Time stamp and text overlays • Configurable motion detection windows • Configurable brightness, saturation, contrast Video Compression • MJPEG format compression • JPEG for still images Video Resolution • 640 x 480 at 20 fps • 320 x 240 / 160 x 112 at 30 fps Audio • PCM Connectivity • 10/100 BASE-TX Ethernet port • 802.11n/b/g wireless with WEP/WPA/WPA2 encryption • Operates over 2.4 GHz frequency band • Single-band 1T1R mode supports a maximum data rate of 72.2 Mbps (PHY rate) using 20 MHz bandwidth Network Network Protocols • IPv4 • ARP • TCP • UDP • ICMP • DHCP Client • NTP Client (D-Link) • DNS Client • DDNS Client (D-Link) • SMTP Client • FTP Client • HTTP Server • PPPoE • UPnP Port Forwarding • LLTD Security • Password authentication • HTTP digest encryption System Integration System Requirements for Web Interfaces • Operating system: Microsoft Windows 8/7/Vista or Mac OS X 10.6 or higher • Browser: Internet Explorer 7, Firefox 12, Safari 6, or Chrome 20 or higher with Java installed and enabled Event Management • Motion detection • Event notification and sending snapshots via SMTP • Sound level detection Remote Management • Configuration accessible via web browser Mobile support • mydlink Lite app for iPhone/iPad/iPod touch, Android, and Windows Phone D-ViewCam™ System Requirements • Operating System: Microsoft Windows 8/7/Vista/XP • Web Browser: Internet Explorer 7 or higher D-ViewCam™ Software Functions • Remote management/control of up to 32 cameras • Scheduled motion triggered, or manual recording • Viewing of up to 32 cameras on one screen options • Supports all management functions provided in web interface Dimensions • Camera only: 60 x 32.15 x 96 mm (2.36 x 1.27 x 3.78 in) • With base: 80 x 80 x 126.6 mm (3.15 x 3.15 x 4.98 in.) Weight • Camera only: 57.8 grams (2.04 ounces) ± 5% • With base: 91.8 grams (3.24 ounces) ± 5% Power • 5 V DC 1 A, 50/60 Hz Power Consumption • 2.84 watts maximum ± 5% Temperature • Operating: 0 to 40 °C (32 to 104 °F) • Storage: -20 to 70˚ C (-4 to 158 ˚F) Humidity • Operating: 20% to 80% non-condensing • Storage: 5% to 95% non-condensing Certifications • CE • IC • FCC Class B • C-Tick Dimensions Diagram ![]() Fiziskie raksturlielumi |
Skatiet arī
