Ātrā meklēšana
Produkta iespējas:
HD PoE Network Camera / HD Wireless N Network Camera
Apraksts:
The D-Link DCS-3511/DCS-3530 are fully featured entry-level HD network cameras, equipped with 1 Megapixel Progressive Scan CMOS sensor and 2.8 mm to 12 mm DC iris vari-focal lens. The cameras can capture HD video at resolutions of up to 1280 x 800 with frame rates up to 30 fps. Snapshots and video can be saved to a network drive, or to onboard storage with the built-in microSD Card slot.
High Definition Surveillance
The DCS-3511/DCS-3530 is built with a megapixel image sensor to give you high-quality snapshots and video with resolutions up to 720p HD. This gives you sharp, high-resolution snapshots and videos with rich detail. Get a closer look with ePTZ, which lets you zoom in, zoom out, and pan across your camera’s video so you can survey a large area easily. A Power over Ethernet (PoE) port* allows you to connect the DCS-3511 to your network and power it through a single cable, simplifying deployment and doing away with the need for a nearby power outlet.
High Speed Access To Multiple Video Streams
The DCS-3511/DCS-3530 supports simultaneous streaming of H.264, MPEG-4, and MJPEG video to provide both high-quality and bandwidth-efficient compression formats. Additionally, the DCS-3511/DCS-3530 supports multicast H.264 and MPEG-4 streaming, allowing users to view the camera feed by subscribing to a multicast IP address on the network. The DCS-3530 also has wireless connectivity which means there is no need for additional cabling, allowing for flexible placement and hassle-free installation.
A Complete, Expandable Surveillance Solution
The DCS-3511/DCS-3530 is a self-sufficient surveillance solution, capable of recording snapshots and video to a microSD card without requiring a PC or network storage device. If you want to expand your surveillance options, D-ViewCam management software is also included, giving you the ability to manage up to 32 cameras with a robust set of features, including multi-camera views and automated e-mail alerts to keep you informed of suspicious or unusual activities.
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
