Ātrā meklēšana
Produkta iespējas:
2.488Gbps Downstream/1.244Gbps Upstream GPON OLT Transceiver
Projektiem
Apraksts:
DEM-PB1S-OLT GPON OLT transceiver module is designed for Passive Optical Network (PON) application and provides 2.488Gbps downstream and 1.244Gbps upstream data rates. It is compliant with ITU-T G.984.2 standard.
DEM-PB1S-OLT is provided with receptacle connector complied with SC connector industry standard.
The module is designed for using in DPN-6608 GPON OLT.
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
