DES-6510EOL EOS
24-Port 10/100 RJ21 Module For DES-6500 Chassis
Apraksts
The DES-6510 is a 24-port 10/100BASE-TX Ethernet module for the DES-6500 chassis switch. Designed to take full advantage of the DES-6500 chassis switch's advanced network functions that link core switches together , this module provides a high port density of 24 10/100BASE-TX ports in 2 RJ-21 connectors. System integrators wishing to set up a high port density network can install these modules in the DES-6500 chassis together with the DES-6506 patch panels.
All ports on the module support auto-sensing 10/100Mbps dual speeds, full/half duplex and auto-MDI/MDIX plug and play installation. The DES-6510 10/100BASE-TX module fully complies with IEEE 802.3/802.3u and 802.3x standards. It supports 802.3x Flow Control for greater dependability and minimal packet loss.
Īpašības
Standards
- IEEE 802.3 10BASE-T
- IEEE 802.3u 100BASE-TX
- ANSI/IEEE 802.3 NWay auto-negotiation
- IEEE 802.3x Flow Control
Protocol
CSMA/CD
Topology
Star
Data Transfer Rates
- Ethernet:
  10Mbps (half duplex)
  20Mbps (full duplex)
- Fast Ethernet:
  100Mbps (half duplex)
  200Mbps (full duplex)
Network Cable
Ethernet Cat. 5 cable (max. 100 m)
Number of Ports
24 10/100BASE-TX Ethernet ports
Connectors
2 RJ-21 connectors, each supports 12 Ethernet ports
Sertifikāti
Informācija pasūtījumam
DES-6510   24-Port 10/100BASE-TX Ethernet Module for DES-6500 Chassis Switch
Attēli
DES-6510/A
View from the right
Pārlādēt
Skatiet arī
