High-performance switch DXS-3600-32S with 24 regular-port 10GE SFP + and optional expansion.
DXS-3600-32S is designed for use at the levels of the distribution and core of large enterprise networks, networks of small and medium-sized businesses, as well as data centers, and provides high-speed transmission for applications such as replication and backup, virtualization, video on-demand transaction processing .
DXS-3600-32S is equipped with a 24-port 10GE SFP +, console port, RJ-45 management port RJ-45, a slot for an SD-card memory.
DXS-3600-32S supports the connection of the modules to extend the power switch at the expense of adding additional interfaces.
Expansion ports are equipped with the following number: DXS-3600-EM-8T - 8-port 10/100/1000BASE-T;
DXS-3600-EM-4QXS - 4-port QSFP + (up to 40 Gbit / s per port);
DXS-3600- EM-4XT - 4-port 10GBASE-T .
DXS-3600-32S supports physical stacking using the expansion module DXS-3600-EM-Stack. Module DXS-3600-EM-Stack is equipped with 2 ports CXP, providing a total bandwidth of a stack of up to 480 Gbit / s. In a stack with a linear or ring topology can combine up to four switches .
The modular architecture of DXS-3600-32S provides the ability to select the type of power supply (for connection to a DC or AC), as well as the type of ventilation units (with the direction of airflow from the front panel to the back or vice versa).
Power supplies and fans support the redundancy of N +1 and can be replaced without powering down the switch.
The device is made in a metal case for 19-inch rack .
DXS-3600-32S supports up to 128K entries in the switching table. High performance is ensured by the switch Fabric up to 960 Gbit / s and the rate of movement of packages to 595,2 Mpps .
In the DXS-3600-32S switches implemented standard for this level of security features, access control, fault tolerance and network management. Also DXS-3600-32S supports IGMP Snooping, Port-Based Q-in-Q, static and dynamic routing protocols RIP, OSPF, BGP, multicast function PIM DM / SM (IPv4), IGMP v1/v2/v3 .
In future versions of the software a switch features of DXS-3600-32S will be expanded. Virtual stacking (up to 32 devices), remote traffic analysis RSPAN, access control Web-based and MAC-addresses, ISM VLAN, Private VLAN, ERPS, IPv6 Tunneling, Loopback Interface, Trusted Host, Ethernet OAM , technology support Microsoft NAP, network load compensation function Microsoft NLB, the functional for use in data centers DCB (802.1Qaz, 802.1Qbb, 802.1Qau ).
Switch DXS-3600-32S, and plug-ins DXS-3600-EM-8T, DXS-3600-EM-4QXS and DXS-3600-EM-4XT will be available for order from authorized resellers of D-Link in the II quarter of 2012 .
Extension module for DXS-3600-EM-Stack will be available for order from authorized resellers of D-Link in the III quarter of 2012 .
