חיפוש מהיר
תכונות המוצר:
VOIP Gateway עם 32 יציאות FXS, יציאת WAN, יציאת LAN
דגם לא מיוצר יותר
מאפיינים כללים:
Specifications:
Interface Device
·         32 port FXS c 2 RJ-21 connectors
·         Port 10/100BASE-TX RJ-45 WAN
·         Port 10/100BASE-TX RJ-45 LAN
The types of connections
·         DHCP-Client
·         PPPoE-Client
·         PPTP
·         Cable BigPond (Australia)
Phonebook
·         Server Management phonebook, up to 200 entries IAD
SIP
·         Registration port "By Port" "By machine
·         Dialing in the standard E.164
·         Support for the backup SIP PROXY (registration)
·         SIP PING
·         CLIR (Anonymous caller ID)
·         Feature hot line / warm line
·         The functions of the group call
·         Hold, Call waiting
·         Call forwarding: accompanied / unaccompanied
·         Call forwarding: unconditional, busy, no answer
·         3-sided conference
·         T.30 fax pass-through
·         T.38 fax relay
·         Adjustable rate of detection of tones fax
·         Out of band DTMF: RFC2833, SIP INFO
Voice functions
·         G.711 a / u, G.726 (32K), G.729A, G.723.1
·         Adjustable jitter-buffer
·         Adjustable size (depending on the codec)
·         Detection and noise
·         The local phone book can lead to other VoIP-device without registration
·         Speed dialing
·         Restrict calls - to take / refuse to call for IP-addresses
·         ID-generation FXS-Call: DTMF, FSK (Bell core / ETSI)
·         Support button FLASH
Management
·         Web-interface and Telnet, IVR
Indicators
·         Power
·         Reset
·         Alarm
·         Run
·         From 1 to 32
Physical parameters
Input voltage
·         90-260 VAC, 50/60 Hz
·         Internal power supply
Dimensions
·         442 x 330 x 43 mm
·         Set in 19 "rack, 1U height
Weight
·         4.1 kg
Operating temperature
·         From 0o to 45o C
Storage temperature
·         De-25o to 75o C
Humidity
·         Up to 95% non-condensing
Emission (EMI)
·         FCC Class A
·         CE
Security certificate
·         UL
      Warranty
·  2 years
נתונים פיזיים
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
